z28 sway bars
Old Oct 26, 2002 | 08:28 PM
94TeALFiReBiRd's Avatar
z28 sway bars
hoe much bigger are they than v6 ones i got them from a owner of a z28 for FRee!!
Old Oct 27, 2002 | 01:51 AM
blue95's Avatar
you have a 94 so the front is the same (30mm) but the rear is a small upgrade for yah there. You have 17mm the V8's should be 19mm but not bad considering aftermarket is 21mm. With the way our cars are setup it will help with the understeer some with a slightly stiffer back end. Get some poly bushings while you are at it and see how yah like it before you go for something else. Might not be a huge upgrade but you can't argue with free.
Old Oct 27, 2002 | 06:16 PM
ok sounds good ill prob get em after winter i still need to get them sand blasted for they look better!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
