gauge cluster
Old Oct 16, 2005 | 07:20 PM
blazzinbird's Avatar
gauge cluster
will the gauges froma 97 t/a work in my 96?
sorry if this is in the wrong forum
Old Oct 17, 2005 | 11:34 AM
EKO's Avatar
EKO
Re: gauge cluster
I don't think they line up.
Old Oct 17, 2005 | 11:38 AM
95HellBird's Avatar
Re: gauge cluster
it'll fit as long as its not digital otherwise you gotta getta different cpu setup, and then you got to take the speedo to a pontiac certified shop and get them to set the gauge to your miles.
Old Oct 17, 2005 | 07:07 PM
Fastbird93's Avatar
Re: gauge cluster
Actually, the 97 digital clusters WILL work in a 93-96 Firebird. Both of my 93 Trans Am's have the 97 digital clusters in them. Everything works as advertised with exception to the fasten seat belt light (doesn't go off) and the TCS OFF light (again, doesn't go off). It's a simple process to open up the cluster and block off those lights though.
Old Oct 18, 2005 | 08:04 AM
Honda Hunter's Avatar
Re: gauge cluster
If that's the case then the 97 T/A will plug into the 93-98 camaro? Also was 1997 when the T/A went digital?
Old Oct 18, 2005 | 03:56 PM
Fastbird93's Avatar
Re: gauge cluster
I'm not sure if it will plug into a camaro or not. Never tried that. Mid 97 is when the gauge cluster swapped from the analog to digital odometer.
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
