Camshaft upgrade.
Old Oct 9, 2005 | 01:11 PM
Pneumatic_Tire's Avatar
Camshaft upgrade.
In the future I think I might like to slip in a better cam for my stock 305 tpi. What year was that they had a really good cam? like 89 or something? Can I find a cam with the same lift/duration without making mine a roller motor? Thanks.
Old Oct 9, 2005 | 01:30 PM
85_305's Avatar
Re: Camshaft upgrade.
Just go aftermarket Jon. Go aftermarket cam and intake (maybe a HSR or something) and you will be in business.
Old Oct 9, 2005 | 05:10 PM
90rocz's Avatar
Yeh, like said, aftermarket will be better than the '89- 235hp 305 cam. Use something "mild" for a 350, it'll be "hot" in the 305, like a base LT1 cam as on another thread, depending on your modds. Newer tech = more power and efficient.
Check out GMPP online at www.gmgoodwrench.com
Old Oct 9, 2005 | 07:23 PM
85_305's Avatar
I would just call up Comp, Crane, Isky etc... and talk to an in-house mechanic and they will tell you EXACTLY which cam you will want for EXACTLY what you want it for. Oh ya, and they all make custom cams if need be
I would NOT go for an LT1 cam though. If you have it laying around, go for it. But otherwise I would do it proffesionally and right the first time around.
Old Oct 9, 2005 | 07:32 PM
I figured I'd hear go aftermarket. I'll check em out. But can someone tell me the stock lift/duration of this crap cam in my 86 tpi? its also a automatic car, for now.
Old Oct 10, 2005 | 12:23 AM
Compstall's Avatar
I've got my entire stock setup sitting in boxes. Cam, lifters, lifter retainers, valve springs, keepers, pushrods, rockers, etc. The lifters have been bathing in a coffee can of fresh oil since I took them out. They look just as good as the new ones I put in. $100 shipped to anyone's door.
Old Oct 10, 2005 | 08:46 PM
90rocz's Avatar
!986 was rated at 25 LESS hp than the '85 LB9. 215 '85/190 '86...
Old Oct 14, 2005 | 09:35 PM
Damon's Avatar
1986 TPI motor in the Camaro/Firebird all came with what has affectionately become known as the "peanut cam." It's a wimp. Tiny duration, tiny lift. In 86 they hadn't even put roller cams into the motors, either. Still a flat tappet. So you can't just bolt in an LT-1 roller cam anyway.
Fortunately, flat tappet cams are cheap. You'll have plenty of choices available from the aftermarket. Check out Comp Cam's like of flat tappet Xtreme Energy cams available for fuel injected TPI engines. These are just like the regular Xtreme Energy cams but on a wider TPI-friendly Lobe Separation Angle. Something like this would be a fire-breather compared to your stock "peanut cam":
http://compcams.com/Technical/Search...umber=12-249-4
It's a little hotter than the factory 305 HO cam they used in those days. Obivously, there are bigger cams available, but this one would be a bolt-in and would probably even run pretty well with the stock chip. The bigger the cam the more critical a custom tune becomes.
Old Oct 15, 2005 | 09:35 PM
Thanks all!
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
