4 channel 12 bolt in a 3 channel car. I have ABS light on, AND Brake light. Normal?
Old Sep 24, 2005 | 10:40 PM
dbusch22's Avatar
I put a 4 channel 12 bolt in my 94 that was factory 3 channel... knowing full well that i wouldn't be able to use the ABS function. no biggie, i expected the ABS inop light to be on, but not the standard brake light? would this be normal. the sensor is not even plugged in, i left it on the old rear end. I put everything else back on the way it was. the lines are bled, the fluid is topped off. Just want to know if i should suspect something since both lights are on instead of just the ABS light
Old Sep 27, 2005 | 08:56 AM
dbusch22's Avatar
Re: 4 channel 12 bolt in a 3 channel car. I have ABS light on, AND Brake light. Normal?
ttt
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
siguy
Nov 27, 2014 10:07 AM
