screech in left rear on left turn (help!)
Old Oct 25, 2002 | 09:55 AM
jeff13's Avatar
After new brakes, new bearings, changed out stock rear end ...I still...can't figure out this metal on metal screeching only when I'm turning left fairly hard.
Thought if anyone was going to know where to go, what to try it would be you guys!!
Thanks for any suggestions.
Old Oct 25, 2002 | 01:21 PM
LPEdave's Avatar
It's probably your brake caliper. Take a look at the diagnostics page in my sig...
Dave
Old Oct 25, 2002 | 01:57 PM
jeff13's Avatar
Smile
Thanks a ton!
the problem was very similiar to what your Tech bulletin described. The new brakes were the not the original stock replacemant (done at a quicky place)and the tab was on the inside rubing ...but only as I turned causing it to get close enough to touch(apparently).
The new mechanic just called me after spending 2 hrs trying to diagnose it.
Moral of the story: Even seemingly simple jobs should be done by a pro!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
