99 trans am cranks but then dies!!!????
my 99 trans am got water over the roof by katrina.
did all post flood things to save it.
but ever sense, it cranks and stays cranked for a little bit but then dies.
i found that if i squirt gas or throttle body cleaner directly in to the throttle body it stays cranked longer. i touched the throttle plate and it was ice cold is this normal.
obd2 scanner gave me a "tps/pedal position low input" code , what exactly does this mean.
i was also told that the passkey feature could have something to do with it.
i had similar probelms with my 94 formula a yr ago and there was a probelm with one of my ignition switch wires could this be the case with my 99 trans am.
PLEASE HELP!!!!!!!!!!!!!!!!!!!
Re: 99 trans am cranks but then dies!!!????
i checked fuel pressure and it is fine.
if its not getting fuel then why does it crank up at first.
would a few of the injectors being clogged cause it to die.
on a lt1 its most likely your ignition switch. or alarm causeing a probelm with your ignition switch.
i had the same probelm with my lt1 but cant get it fix on my ls1
I had the same problem with my car its a 95 had to put a new filter and fuel pump in it...works great, but i don't know about yours, sorry i am no help...ur sure its not the pump though?
it fires up with out the flammable liquid.
when i turn the key it fires up like normal for about 2 sec and then dies.
if i have my brother spray the flam liquid in it , it stays cranked.
i dont know if the computer is shuting it off , if its my ignition switch (like in my lt1) , or if it is gettin a constant flow of fuel to it.
do you think if the injectors were clogged could have something to do with it.
I meantioned it is happening on my LT1, but could my choke be sticking open when it doesn't need to be? Just something that crossed my mind. I am thinking about giving it a fresh tune-up this weekend though.
i would try the ignition switch.
i found that if turned the key back and forth just right it would stay cranked.
but my 99 trans i cant get this to work.
