Simple 1LE sway bar question
The font 1LE is hollow, 32mm, and weighs 13lbs if my notes are correct. Since it's larger than the stock hollow bar, I suspect it's a touch heavier than stock, but not much. I don't happen to have the weight of the stock bar.
The rear, I have less info on. The stock bar is 19mm hollow. In 1993, the 1LE was 21mm, solid, and weighed 10lbs. Later model 1LE's had a 19mm hollow bar, I don't know the weight.
Dave
Dave
F'n1996Z28SS
Aug 23, 2023 11:19 PM
