Will WS6 springs from an LS1 work on an LT1 car???
Old Sep 14, 2005 | 06:40 AM
Camarocracy's Avatar
Would springs from a 98+ WS6 car work on an LT1 car??? I know the LS1 springs are stiffer then the LT1's.
Old Sep 14, 2005 | 08:09 AM
Steve0's Avatar
Re: Will WS6 springs from an LS1 work on an LT1 car???
Yes. The springs are interchangable.
I believe though that the ws6 springs are 360in/lb while the stock lt1 front springs are 310in/lb. The rear springs should be the same. I doubt the spring rates will be that noticeable. Someone else will have to back me up on that statement. I'm not 100% sure. If the WS6 springs are not an upgrade over stock LS1 springs, then they woulud actually be softer than what comes on a LT1 car.
Old Sep 18, 2005 | 06:43 PM
Severous01's Avatar
yes they would work, but remember: the ls1 cars have an advantage in weight. the engine weighs about 100 lbs lighter due to it's aluminum block. but if you're willing to try the experiment, i have a new, barely used (about 3000 mi) set of front only slp springs. 50 bucks and shipping and they're out the door.
Noenav
Mar 1, 2019 07:38 AM
mspennyhughes
Nov 28, 2014 03:22 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
