Rattling Borla
Old Sep 10, 2005 | 07:51 AM
UK_chevyV8's Avatar
Unhappy Rattling Borla
My Borla only just fits, it looks and sound great but when I drive slowly on poor roads something rattles, I stuffed a couple of exhaust “O” rings between the heat shield and the muffler and I think that cured it but they keep falling out.
Does anyone know of some sort of heat proof sticky backed matting that I could stick on top of the muffler?
Or is there a better cure, is anyone else having the same problem?
Old Sep 11, 2005 | 07:19 AM
Steve0's Avatar
Re: Rattling Borla
You could cut some thin "slices" of rubber heater tubing like the kind the rubber tubes that carry water/coolant under the hood are made up of and create a spacer. They shouldnt give you any problems with regards to eat.
You shouldnt have the rattling problem... I dont with my Borla. Is yours bolted or welded together? If its just bolted up, loosen the exhaust, make some spacers, and insert them where the muffler is rattling at giving ample clearance. Then retighten the exhaust and remove the spacers and it ought to stay put where you tighted it.. I would give that a try.
Old Sep 11, 2005 | 04:43 PM
UK_chevyV8's Avatar
Re: Rattling Borla
Thanks Steve0, yep its bolted together, making spacers is a good and simple idea, I will have a go next weekend.
I spent hours putting it together and it does not fit very well, for example the bit that goes over the axel has to be as low as it can and even then it almost touches the body.
I thought I had fixed it a few a weeks ago because I found 2 screws missing from the heat shield.
WobblySausage
Oct 7, 2015 02:44 PM
autoxr166
Sep 25, 2015 04:21 PM
KYWes
Aug 10, 2015 07:03 PM
colts0455
Jul 28, 2015 11:28 PM
squarehead
Nov 21, 2014 08:02 PM
