PanHard Rod
Old Sep 10, 2005 | 07:18 AM
FormulaLT1Power's Avatar
PanHard Rod
May sound like an iggnorant question...but what is the difference/benefits of both the adj/and non adj PHR. Thanks.
Old Sep 10, 2005 | 07:36 AM
2000GTP's Avatar
Re: PanHard Rod
An aftermarket panhard rod will increase the lateral stability of your rearend. Adjustable rods are beneficial because they allow for centering and alignment of the rearend after lowering or clearancing bigger tires.
Old Sep 10, 2005 | 09:39 AM
Re: PanHard Rod
So basically since my car is not lowerd, and I do not have a huge tire difference I will be okay with a normal PHR? Basically, I do not have any suspension mods and deciding what to do after SFC. PHR are relativly cheap and seems like it could help the most. I've read a few things showing how to install the PHR...is it pretty easy? Thanks for any responses.
Old Sep 10, 2005 | 10:53 AM
Bud M's Avatar
Re: PanHard Rod
My next mod after SFCs would be a stiffer front swaybar.
Old Sep 10, 2005 | 01:03 PM
2000GTP's Avatar
Re: PanHard Rod
Yes, a new non-adjustable panhard rod is a good choice, along with lower control arms, subframe connectors, and maybe even freshen up the stock rear swaybar with new poly bushings and endlinks.
Old Sep 10, 2005 | 01:21 PM
luckyou03's Avatar
Re: PanHard Rod
if I were to run 17x11 rims on the rear without any clearancing to the car, would I need adjustable or non?
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
