dropping a 3800 into my Isuzu
Old Aug 15, 2005 | 12:07 PM
CPOM's Avatar
Hi I have planned out a major buildup of my 92 isuzu Pickup that I use for offroading.
I'm dropping in a 3800 from an 02 Camaro. Im going to try and run the engine on a Megasquirt (megasquirt.info) custom fuel injection controller managing both fuel and spark.
I have a few questions maybe you 3800 gurus can answer.
1-Can the electronic throttle body be swapped out for an earlier cable linkage one? if so what was the breakppoint in year they converted over?
2-What sensor is just behind the throttle body just to the side of the EGR port on this intake manifold?
3-What is the best source of wiring diagrams for this engine harness? I need to graft my existing Isuzu harness connections, GM motor so its a GM harness actually, to the 3800 harness.
If anyone cares to see this sort of thing on here I will post updates and pics to this thread.
here's a pic of me pulling the GM 3.1 that came stock:
http://berisford.net/uploads/cpom/projectpup/12.jpg
truck as it looks now:
http://berisford.net/uploads/cpom/projectpup/pt2/4.jpg
http://berisford.net/uploads/cpom/projectpup/pt2/5.jpg
http://berisford.net/uploads/cpom/projectpup/pt2/6.jpg
http://berisford.net/uploads/cpom/projectpup/pt2/7.jpg
Old Aug 15, 2005 | 12:25 PM
89385formula's Avatar
Re: dropping a 3800 into my Isuzu
I can't really help you with you questions, however I want to say thats a pretty cool lil project you got there...sounds like fun.
Old Aug 15, 2005 | 01:40 PM
deadmeat2004's Avatar
interesting...prob cant help ya either... good luck though and keep us posted...
Old Aug 17, 2005 | 12:20 PM
CPOM's Avatar
I found out the break ocurred in 1998-99 year for throttle body types, this is what I can tell by car-part.com and the drive-by-wire TB will not bolt to this intake manifold. Since the d-b-w TB has no IAC, rather than modifying it to fit a manual linkage I'll try and build an adapter plate for pre-99 cable actuated TB.
I got a subscription to alldatadiy.com for wiring diagrams which has proven to be immensly helpful.
what sensor is this?
fits in a hole in the intake manifold right next to the EGR port here:
Old Aug 18, 2005 | 11:20 AM
EKO's Avatar
EKO
MAP sensor?
Old Aug 18, 2005 | 11:53 AM
CPOM's Avatar
It turns out it is the EVAP purge solenoid. I'll check back with you guys when I start breaking into this wiring harness -- got a subscription to alldatadiy.com for wiring schematics.
Old Aug 20, 2005 | 08:41 AM
CheshireCat's Avatar
I'm just curious... What made you decide on going with the 3.8 from a camaro? I have a 91 Isuzu pickup with the 2.3 and might replace the motor someday...
Old Aug 22, 2005 | 02:12 PM
Tru2Chevy's Avatar
I would think it would have been easier for you to retain the stock PCM and throttlebody....
cool project though.
- Justin
Old Aug 23, 2005 | 04:10 AM
morb|d's Avatar
- Justin
those would be HIGHLY incompatible with a 3800.
Old Aug 23, 2005 | 10:19 AM
CPOM's Avatar
picking the 3800:
I wanted to keep this project simple and reuse my existing trans and transfer case. My stock trans is a MUA5 Isuzu 5-speed. I looked at 3.4s from Camaros and as they have the same pattern as my Isuzu trans. I could also reuse my existing ECM and motor mounts. As I got into the project, my Isuzu trans went south so I was looking at a full driveline swap.
Looking at prices, an old engine needing a rebuild would cost hundreds and hundreds of dollars after parts and machine work, so newer would be better. There really wasn't a cheap 3.4 GM solution so I started looking at camaro 3.8s as I bought a manual covering both 3.4s and 3.8s from Camaros.
Long story short I have an engine that was cheap (under 500 with low miles), good torque curve and will bolt to a Toyota dual case setup, best of both worlds.
Yes it would have been easier to graft in the stock ECM and PCM versus a custom setup but I wanted to experiment with all of the fuel injection settings and build it from scratch. Having a drive by wire throttle doesn't seem like it will be worth the work so I decided to go cable throttle.
I will keep you guys posted on progress, spent last weekend and next weekend out of town but September will see some major progress with this project.
Old Aug 23, 2005 | 10:20 AM
CPOM's Avatar
I think he meant keeping stock 3800 ECM to run the engine, not the Isuzu stock ECM.
Old Aug 24, 2005 | 02:10 PM
Tru2Chevy's Avatar
I meant keeping the original 3800 PCM, rather than going with an aftermarket controller.
- Justin
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
