Engine Noise in the Speakers
Old Aug 13, 2005 | 08:07 PM
drgubler's Avatar
I have a 2002 Z28, and recently when accelerating I hear the engine noise in the speakers. This happens even when the stereo is off. The stereo is stock, and the only real engine mods are N20 and forced air induction.I posted this in the Ls1 tech forum, but they suggested trying the audio section. Any ideas?
Old Aug 14, 2005 | 12:28 AM
Cmr0z28's Avatar
Re: Engine Noise in the Speakers
Sounds like a bad ground somewhere...might have something to do with the N2O wiring?
Old Aug 14, 2005 | 06:37 AM
Eric@Victory Racing's Avatar
That is usually the sign of a bad ground.
Old Aug 14, 2005 | 09:12 AM
LS1 RULZ's Avatar
I don't see how it could possibly be a grounding issue. Not when the noise is happening even with the stereo turned off.
Did this noise start after you added the N2O? If you disconnect the N2O system does the noise go away?
Old Aug 14, 2005 | 04:42 PM
drgubler's Avatar
The noise started after the N20, but about 1.5 years later.
Old Aug 14, 2005 | 05:16 PM
95okz28's Avatar
check your ground ive had it happen on mine and my wifes car and they were both a bad ground.
Old Aug 14, 2005 | 10:08 PM
Cincymaro88's Avatar
same, had a bad ground. regrounded the amp to the antenna mount (piece that the spare tire mounts to which is no longer there) and problem fixed!
Fatdog2
Feb 12, 2015 12:24 PM
phatbasslines
Jan 13, 2015 05:03 PM
Collector Car
Jan 5, 2015 10:58 AM
Rod Bender
Jan 1, 2015 03:18 PM
Omega9
Aug 2, 2002 12:33 AM
