How can I tell if my 98 is a real SS ??
Old Aug 3, 2005 | 06:44 PM
Boosted 98SS's Avatar
i just bought a 98 SS, and was wondering if anyone can tell me if it is a real one or not, how do i tell?? i thought the SS with ram air had a ram-air intake, this one has one that looks like the z28's??? Anyone know?? it has SS badges, and SS hood, just not too sure?? thanks.
Old Aug 3, 2005 | 06:57 PM
Bert02SS
Guest
Posts: n/a
Re: How can I tell if my 98 is a real SS ??
Send your VIN to SLP. They will supply you with a Build # if it's the real thing.
I did that today, am waiting for an answer to find out the Build #
Old Aug 4, 2005 | 01:20 AM
Z28SORR's Avatar
You don't need to contact SLP. Simply look at the RPO codes. If there is a WU8, it's a real SS.
Old Aug 4, 2005 | 01:34 AM
99blackSS's Avatar
Yup, WU8 and the RPO codes are inside the drivers door jam. The 98+ SSs air box looks similar to the Z28s air box except for a rubber strip under the opening to the air box which I would assume is to help direct the air from the hood into the intake.
Old Aug 4, 2005 | 12:50 PM
yeah, its all good then. its there. My car has a VIn of 2G1FP, making it a canadian car?? but was sold new in 98 at a dealer in Missouri, anyone elses car like this??
Old Aug 4, 2005 | 01:32 PM
98supersport's Avatar
The camaros were all made in Canada... hence the Canadian code. Mine starts with the same series and was bought new in Colorado Springs, CO. If you want to know your build number (xxx out of xxxx made that year) you will need to contact SLP and supply the VIN.
Do you still have the stock exhaust? It should be a single tip exhaust. Most people tore it off almost immediately and replaced it with an aftermarket dual tip system. That exhaust was only installed in 98' on SS cars. I believe SLP had an option later towards the end of 98' to replace that system with a dual tip SLP system.
Also- your rims will have a GM stamp. That was the first year GM made their own ZR-1 style rims. Earlier OEM rims had the previous company's stamp. Chrome wheels became an option towards the end of the year.
-Scott
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
CARiD
Sep 7, 2015 08:21 AM
