HELP: Zex Kit - Wet vs. Dry
Old Aug 3, 2005 | 05:35 PM
1quickTA's Avatar
A friend of mine here at school has a friend who is trying to sell a Zex nitrous kit (practically brand new) for $300. It was on his car when he bought it and over the phone he said he thought it was a wet kit which is exactly what I wanted and I was going to buy it. However, I just got pictures and it looks like there is only one line going into the nozzle so i think its a dry kit.
I am pretty new to nitrous but from what I have read I wanted to go with a wet kit because it seemed a little safer since you aren't relying on your stock injectors and such. I want to run a 100 shot. Do you guys think I should go for this dry kit??? Please let me know about the pros and cons of a wet vs. dry for a 100 shot on an LT1. Thanks.
Old Aug 4, 2005 | 07:20 AM
LWillmann's Avatar
Re: HELP: Zex Kit - Wet vs. Dry
You can get a brand new wet nitrous kit for as low as $399, so if you're wanting wet, why not go that route?
Old Aug 4, 2005 | 10:48 AM
1quickTA's Avatar
where can you get one at that price? And what brand??
Old Aug 4, 2005 | 01:33 PM
LWillmann's Avatar
Dynojet kits start at that price. I can't speak on their quality, but they seem to be fairly popular here.
Old Aug 4, 2005 | 09:45 PM
Boosted 98SS's Avatar
The only problem with a wet kit is pooling, then BOOM !!!!
As most of us know, nitrous is unflamable, do a dry kit is a lot saffer. If I was you, I go dry!!
Old Aug 4, 2005 | 10:04 PM
1quickTA's Avatar
The only reason I was leaning towards a wet kit is because I am somewhat nervous about relying on the stock injectors and fuel pump. If I were to run a 100 shot, would that even be worth worrying about??? I never really thought about the fuel pooling either.
Old Aug 5, 2005 | 09:08 AM
JBird33's Avatar
You can run a 100 shot without upgrading your stock fuel system (I believe, someone correct me if I'm wrong,) and if ran in conjunction with a fuel pressure safety switch should keep you from running too lean unexpectedly and blowing your motor.
Old Aug 5, 2005 | 10:29 AM
LWillmann's Avatar
Fuel puddling typically happens when the intake velocity is low. That's why most kit manufacturers recommend only using nitrous above 3000 RPM.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
