need help- oil pan/girdle clearance
Old Aug 3, 2005 | 12:04 PM
bumpnzx3's Avatar
here is the deal: i have a roller 350 block that i am in the process of building/stroking to replace the tired 406 that's in my s-10 right now. i bought a main girdle for the 2 bolt- and the stock late model oil pan won't fit around the girdle. it's my understanding that girdles always require some "massaging" to get them to fit correctly- is this true? also- will the 400 oil pan i have now fit on the late model roller 350 block i have? if so- is it any wider or have the strengthening ribs that the 350 pan apparently has. i can't see any of this first hand as one of my friends that teaches auto shop at a college 2 states over is doing the machine work for me. he is a mopar guy- so he doesn't know much about the chevy oil pans. he says we either need something a little wider or no strengthening ribs in order to get the pan to clear- or at least clear with a less grinding involved. he also said the oil pan that he has there at the shop for a late model roller slants inward a little- and he thinks the 400 pans don't do that- anyone want to confirm this?
Old Aug 3, 2005 | 06:18 PM
markinkc69z's Avatar
Re: need help- oil pan/girdle clearance
Why did you buy a girdle for a sbc? They don't break caps or cranks. Put studs in it and line hone the block and be done. The pan won't fit the 1pc seal block without a 2pc conversion and crank.
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
carl.froehlich
Mar 13, 2015 12:38 AM
