pulley combo
Old Jun 16, 2005 | 11:34 AM
blueta's Avatar
pulley combo
I'm looking at a vortech with 2 crank pulleys and 1 blower pulley. The crank pulleys are 6" and 6.66" and the blower is 3.33. Is the lowest I can run with these combo's 6psi? It has custom hard tubes also so I'm sure the boost will even be a little higher. I don't want to run more then 5 really. I have a zz9 cam with stock iron heads with a vavle job. That's all for main engine mods besides bolt on's. What size pulley's should I run?
Old Jun 16, 2005 | 10:18 PM
OBE1 95Z28's Avatar
Re: pulley combo
The stock 6 psi system from Vortech uses the 6"/3.3" pulley combo. The 6.6" crank pulley will probably get you up to 8 psi. I run the 7"/3.3" combo through an aftercooler and have the Brad Brand hard intake tubing and get 10 psi through mildly ported heads.
Old Jun 16, 2005 | 11:06 PM
blueta's Avatar
Re: pulley combo
Ok, so if I want to run less then 6psi with the hard tubes is there a combo for that? Do they make a bigger blower pulley? Smaller crank pulley? I'm trying not to blow my engine up too soon lol. thanks.
Old Jun 17, 2005 | 09:45 PM
OBE1 95Z28's Avatar
Re: pulley combo
Even if Vortech makes a bigger blower pulley, it may be a challenge getting things to fit. My 3.3" pulley is in close proximity to the upper radiator hose and bypass tube. One option may be to shift sooner as boost is a function of rpm.
Old Jun 18, 2005 | 12:21 AM
blueta's Avatar
Re: pulley combo
Well I don't think the rad hose will be too much of a problem since my setup is totally custom in my car and I can just make a new one My trans shifts at only 4500rpm unless I shift it by hand lol. I could also just loosen the belt up so it slips I guess I could just run the 6psi if I had to...It's just that I don't have any knock system on my car and possibly have cast pistons cause the previous owner of the engine keeps getting confused about what is in there. So I was a little worried about those 2 things.
AviatorDave
Dec 19, 2016 06:35 PM
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
