South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Need a shop to rebuild my T56
Old Jun 1, 2005 | 04:13 PM
nitro_velocity's Avatar
I've purchased all the parts for the rebuild on a T56 transmission and I also have a spec stage 3 clutch and aluminium flywheel to be installed. I have callled around to several shops and people are asking around a 1000 bucks for just the labor. I personally think this is a ridiculous amount for a ten hour job tops. Does anyone know of a shop that might be a little bit more reasonable or am I being unreasonable thinking that that is way too much?
Old Jun 1, 2005 | 05:13 PM
SFB767's Avatar
Re: Need a shop to rebuild my T56
If you don't mind the drive, Harrell & Beverly in Sanford are great. I had my trans. worked on there when a seal went bad.
The easiest way to get there is to take S.R. 44 in from Brevard County into Seminole County and they'll be on the left side of the road when you're in Sanford just before you hit 17-92. They have a yellow and black sign. I think their number is 407-321-8400.
Old Jun 1, 2005 | 06:00 PM
2002Z28SSConv's Avatar
SR44 goes further North. SR46 goes through Sanford.
Old Jun 1, 2005 | 08:11 PM
SFB767's Avatar
Arrow Re: Need a shop to rebuild my T56
Oops!
I meant to say S.R. 46, I don't know why I put 44.
Old Jun 1, 2005 | 09:28 PM
What about price? Does anyone have thought on that? Thanks for the shop I'll definetly give em a call.
Old Jun 2, 2005 | 08:15 AM
The Vette Dr's Avatar
The labor for R&R and overhaul should be in the $650-750 area. Plus any sealer, fluids, parts forgot or missed. Hope this helps.
Mike Norris
Old Jun 2, 2005 | 04:07 PM
Thanks for the help mike. You'll probably be getting a call.
Old Jun 6, 2005 | 11:29 PM
JimMueller's Avatar
$1000 just for labor? The last two times I had my M6 tranny rebuilt, the labor was right around $300, plus whatever parts it needed. I didn't replace the clutch at the same time - but if you're already in there I don't see where that extra $700 is going
Old Jun 7, 2005 | 06:38 AM
Hey jim where did you get your work done? I need this done asap.
Old Jun 7, 2005 | 06:53 AM
Jim,
I doubt it was $300 for the R&R and the trans overhaul. If so, they are pretty much doing it for free if it is a real shop and not a backyard repair. It is usually that much for each. Correct me if I am wrong.
Mike Norris
Old Jun 7, 2005 | 02:56 PM
JimMueller's Avatar
I just spoke with Jake. He said $250 to rebuild the tranny if it's out of the car. $450 if they have to drop it themselves. Maybe an extra ~$100 to replace clutch, turn flywheel, etc. Few days lead time.
Old Jun 13, 2005 | 07:58 PM
That sounds more like it
Mike Norris
Sergio
Jan 27, 2016 04:27 PM
Devinfoote87
Parts Wanted
Apr 14, 2015 04:29 PM
737drivr
Feb 20, 2015 12:00 PM
importkiller94
Jan 17, 2015 09:03 PM
