New spark Plug and wires replacement
Old May 25, 2005 | 08:08 AM
91_ragtop's Avatar
Unhappy New spark Plug and wires replacement
Hi. great forum guys.
I replaced the plugs, wires, rotor and cap on my 91 305 TPI yesterday and it idles funny. I labelled everything before taking it off, but somehow must have rewired it wrong. I know the firing order, 1 8 4 3 6 5 7 2 .
My question is, where do I start on the distributor? I don't know which plug goes with what prong on the distributor.
Can anybody please help. I don't want to drive the car the way it is.
Also, has anybody ever used the Bosch Platinum +2 plugs that do not need gapping? I installed 8 of these Bosch plugs with the two prongs.
Thank you very much.
Old May 25, 2005 | 09:15 AM
Ben91RS's Avatar
Re: New spark Plug and wires replacement
You start on the prong on the distributor that is closest to the #1 cylinder, and then work clockwise.
Here's a diagram:
Old May 25, 2005 | 09:20 AM
91_ragtop's Avatar
Awsome. Exactly what I was looking for.
Thank you very much
Old May 26, 2005 | 11:04 PM
thorguy57's Avatar
If you still have problems with it it could very well be the platnum plugs. I put a set in my 01 Jeep Cherokee and it would not idle worth a crap till I took them out and put cheap champion truck plugs in it. It would idle iractically about 400 rpms. Just something else to check into.
Old May 26, 2005 | 11:27 PM
Runin2Nite's Avatar
those platnum 2's suck... the tips end up breaking off into your motor and then u got sum problems!!!
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
