Will 94+ 6 speed mount to a Olds 1969 455 ?
Old May 24, 2005 | 06:54 PM
RobocopHWH's Avatar
Curious if this will mount up. My 69 442 has a th400 and i would much rather have a manual transmission that won't give out as easily as the GM 4 speed. I know alot of the GM tranny mounts and whatnot are the same, just wondering if anybody knows this for a fact. Soon to also be a m6 owner Thanks for the help guys
Old May 24, 2005 | 07:01 PM
Birdman7389's Avatar
Re: Will 94+ 6 speed mount to a Olds 1969 455 ?
I know the bolt pattern will be different. You can probably find an adapter, but then you have to figure out clutch hydraulics....
Old May 24, 2005 | 08:10 PM
ayalam's Avatar
My brother has a 71 cutlass supreme and it will fit in the car. But the problem is, is that he put a 1998+ transmission in with the motor . So no advice as to will it fit the sbo. you can goto realoldspower.com and ask those guys.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Dec 17, 2014 01:12 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
