Temp Gage
Old May 22, 2005 | 10:30 PM
Chevrolet Bailey's Avatar
Temp Gage
How would i install a mech Temp gage in a 99 Camaro LS-1, Where would the probe go in the head. Thanks
Old May 23, 2005 | 11:20 AM
97bowtie's Avatar
Re: Temp Gage
A lot of guys install the plug into the block freeze plug just above the starter. Another way you can do it is to pull the brass plug out of the rear of the passenger side head (by #8 cylinder) and install the sending unit. You'll have to drill/tap the head for the sending unit or use an adapter. Tests have shown a 1-2* difference between the head and block locations...either will work OK.
Old May 23, 2005 | 02:27 PM
footbraker's Avatar
Question Re: Temp Gage
Good question, Bailey.
Who makes an aluminum tube with 1 1/2 inch ends with a 1/2 NPT hole in the middle? "Be Cool" has a 1 3/4 inch tube with a petcock. The hole for the petcock is probably a 1/2 NPT hole and a racer could remove the petcock and install the fitting for a water temp mechanical gauge. I have measured the upper radiator hose and it has a 1 3/8 I.D. I don't think it would be advisable to stetch it for a 1 3/4 tube. I think the hose would fail eventually because of the stress. I think a 1 1/2 inch tube would work fine. Moroso has one that has a 1 1/2 inch end with the other end 1 1/4 inch. I don't want to use it. It would probably work, but I need a tube which is 1 1/2 inches on both ends.
I read in my LS1 service manual that the 1999 LS1 water pump directs the water into the block, unlike the LT1 which is allegedly reverse flow (heads to block flow). Anyone know if either is true?
Old May 23, 2005 | 02:55 PM
Re: Temp Gage
Steve you have got to be pulling my leg, Chevrolet William
Old May 23, 2005 | 03:03 PM
footbraker's Avatar
Re: Temp Gage
LMAO @ Bailey!
Old May 24, 2005 | 03:21 PM
footbraker's Avatar
Re: Temp Gage
Well, Bailey, I guess there weren't any tapped and plugged holes in the LS1 block or heads.
93 RedBird
Nov 15, 2015 08:24 AM
1bad427ls1
Sep 23, 2015 01:12 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
