New rims and tires
Old May 12, 2005 | 04:38 PM
94NDTA's Avatar
New rims and tires
I went from 16x8's to 17x9.5s and 17x11's in the back. Should I a new front end alignment?
Old May 13, 2005 | 01:08 AM
Zack's Avatar
Re: New rims and tires
look at your old tires..are they excessively worn on the inner edge of outside edge? if not, no alignment
Old May 13, 2005 | 07:54 AM
94NDTA's Avatar
Well, I havn't had it aligned in 3 years, the first pair of tires were only on for about 1,500 miles, and this pair has been on for about 3,500. The other pair of tires were brand new, so I can't see any visable wear. I am just trying to fix a shaking of the steering wheel I get at 90-100 mph, and was wondering if this was it.
Old May 13, 2005 | 08:57 AM
Zack's Avatar
shaking is most likely the balancing
Old May 13, 2005 | 09:05 AM
94NDTA's Avatar
Of the rims and tires? The rims and tires are balanced.
Old May 16, 2005 | 06:47 PM
94NDTA's Avatar
Anyone else?
Old May 18, 2005 | 06:21 AM
GCEZ28's Avatar
3 years?? How many miles? I would suggest getting it to a good front end shop and have any worn parts replaced and an alignment. I can almost guarantee that if you drive it regularly that by now you need some parts replaced. at minimum, an alignment.
Old May 18, 2005 | 09:05 AM
94NDTA's Avatar
uhh....3800 miles. It still only has 26K
Old May 18, 2005 | 10:23 PM
Reznor's Avatar
clean.
what offset in the rear?
where'd you purchase the wheels from?
i want to get 11's in the back, but they stick out too much on the sides
Old May 19, 2005 | 08:55 PM
94NDTA's Avatar
50 mm, they fit perfect, not sticking out on the side. I forget where I got 'em.
Old May 19, 2005 | 10:18 PM
jchevy's Avatar
Originally Posted by Reznor
clean.
You have probably seen the 17x11's with the 36mm offset. The 50mm doesnt stick out much. If you want I have a picture of mine I can post. They are the 50 mm
Old May 19, 2005 | 10:28 PM
Black_Z28's Avatar
Just don't drive 90-100mph. Simple as that.
Old May 19, 2005 | 11:04 PM
Reznor's Avatar
is 50mm offset the "highest"?
i thought i remember seeing a mfg that offered them in 56mm offset, but can't find it.
i'd like them to be flush with the top of the fender, maybe tuck in just a tiny bit.
jchevy, yea, i'd like to see some pics
Old May 19, 2005 | 11:17 PM
jchevy's Avatar
The 56 mm is the for the 17x9.5 wheel, you run that in the front.
I thought I had a pic that showed it better, but these are the best i can do right now. They stick just inside of the top of the wheel well.
http://mywebpages.comcast.net/jared1181/rear001.jpg
http://mywebpages.comcast.net/jared1181/rear003.jpg
EDIT:
http://jareds95z28.cz28.com/images/IM000383.JPG
Old May 20, 2005 | 12:22 AM
Reznor's Avatar
nice fitment
i think im gonna go with a set of c6 z06 wheels
18x 9.5 ans x11 in rear
should look something like this, but in LS1 form
Quickss96
Jan 29, 2016 05:56 PM
Latronaxe
Jul 20, 2015 12:00 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
