adj/non-adj control/trailing arms RKsports
Old May 2, 2005 | 07:45 PM
slowpoke310's Avatar
what difference would it make with non adjustable as to adjustable trailing/control arms by RK sports??? ive installed a adj, torque arm bar, and have ordered a adj pan hard bar. would it be better to get the adjustable arms?
Old May 2, 2005 | 10:18 PM
OBE1 95Z28's Avatar
Re: adj/non-adj control/trailing arms RKsports
No need for adjustable LCA's unless you plan to run a larger diameter tire.
Old May 3, 2005 | 02:19 PM
i have 20" on now, but am going to take em off and put 19" on. i could afford either or but dont want to spend unnecesary money. plus the specs. on the adjustable ones looked weaker
Old May 3, 2005 | 02:40 PM
OBE1 95Z28's Avatar
It's not the wheel diameter, it's the tire diameter. Tire diameter is usually 26". Some guys run 27" and 28" slicks to get a bigger tire patch for traction.
Old May 3, 2005 | 04:27 PM
thanx 4 the feedbak, ima go with the non-adjustable arms, and adjustable panhard bar, as i do plan to lower the vehicle, once the wheels are changed.
Quickss96
Jan 29, 2016 05:56 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
