Anti Lock Brakes on Third Gen Camaro
Old Apr 28, 2005 | 12:34 PM
Solidous_Snake's Avatar
I want to dramatically improve braking distance. Can I swap out a 4th gens ABS system into a 3rd gen IROC-Z? I figure it would be alot cheaper if it's a used setup as opposed to new. Wha do you think?
Old Apr 28, 2005 | 01:16 PM
respectirocz's Avatar
Re: Anti Lock Brakes on Third Gen Camaro
abs does very little to shorten your stopping distance, what it does is allow you to steer while panic breaking
u wanna stop faster, get some real wide, sticky tires, real big brakes all around, and lighten the car as much as possible
Old Apr 28, 2005 | 01:17 PM
Can you recommend a full brake set up? I want a significant change and feel.
Old Apr 30, 2005 | 07:11 PM
dennisbernalitaly's Avatar
bear or wilwood, pretty expensive, but worth it. I have seen guys drop braking distance 30 to 40 feet with a full front/rear set up, and wide sticky tires.
Old May 3, 2005 | 11:47 AM
bubba353z's Avatar
A lot of guys are doing the LS1 front swap. Check out thirdgen.org - I'm sure there are posts about the swap. Our rears (if you have disks) are not too bad with some good pads. You can also do a LS1 rear swap, if you have drums.
If you have the $$$ though, Baer makes some sweet setups that bolt in.
Old May 3, 2005 | 12:57 PM
i have an 87 iroc and i'm in the process of doing an ls1 brake upgrade
check out bigbrakeupgrade.com
its alot cheaper then the other kits and its alot better than stock
Old May 3, 2005 | 01:15 PM
Sweet. I looked through the link you posted and there all out of stock. Did you order your kit already?
Old May 3, 2005 | 11:04 PM
i didnt order the kit because i can do most of the work myself, and i can get parts cheaper, so i bought only what i need, email him, i'm sure he can work somthing out if you send him your spindles (thats if u can afford to have the car sit for a while)
ChrisFrez
Jan 4, 2015 08:43 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Dec 7, 2014 11:32 AM
19redta96
Jul 23, 2002 12:25 PM
