MT goes 0-60 in 6sec and 1/4mile in 14.3 @ 98.1....
Re: MT goes 0-60 in 6sec and 1/4mile in 14.3 @ 98.1....
WOW ! Maybe GM did lax up a lil on the PCM babaysitters . Considering how much a dissapointment 04-05 GTP performance was , thats ALOT better than I woulda guessed out da box . Seeing that , Im sure one the GP guys will nab a 13 sec Et stock . Nice
Disciple
From: Toronto, Ontario, Canada (20 min. down the road from the "Shwa"!)
My '97 L67 Bonneybeater SE goes 14.5s at 97.xx with only a 3.5" pulley and a 9" K&N open cone. If I put the K&N in a proper cold air box and had a 3.4" pulley, I'm guessin' it would be a dead heat.
Best regardSS,
Elie
Best regardSS,
Elie
Fantastic times.
But it's going to be a bit of a downer to to do it yourselfers. You'll no longer be able to get massive performance gains by simply buy buying a $20 pulley.
Will you even be able to safely make power gains..?? From what I've read its programmed to hold the hp down since the trans cant take it. Which would be a bummer
Originally Posted by guionM
Fantastic times.
And upgraded transmissions and higher stall torque converters wont be far behind .
Be a lot easier to get excited (genuinely excited) if the car drove the correct set of wheels.
Sorry - will get off that theme for now...that horse is now beyond dead.
Am I the only one a little disappointed here? For an engine with as much peak HP as the LS1, in a car weighing about the same as an f-body, it's a good 1/2 second slower. I know, it's a FWD sedan but still, you'd think 300 HP would net you better than a 14.3
