Rear swaybar suggestion
Old Apr 27, 2005 | 12:19 PM
Knowklew's Avatar
Question Rear swaybar suggestion
Well, I have the ST 35/25 sway bars on my car they are SOLID. I plan on keeping the front bar which is 35mm Solid, but i want to swap out the rear bar for something smaller. I have found that the rear tire will come up when i go around a corner hard and its really scary to be blunt. I want a smaller bar but i dont know how small to go. Can anyone help me out?
Old Apr 27, 2005 | 02:43 PM
stereomandan's Avatar
Re: Rear swaybar suggestion
If you have stock springs, then I would either recommend the stock 19mm bar, or the 21mm 1LE bar.
I have stock springs, Bilstein shocks, the solid 35mm ST front bar, and the 21mm rear 1LE bar. I like it.
If you don't have your stock 19mm bar, and want one, I'll sell you mine, plus the stock endlinks and bushings real cheap.
Dan
robcarnut
Mar 20, 2015 03:40 PM
Rod Bender
Jan 1, 2015 03:18 PM
97FormulaWS-6
Sep 11, 2002 11:57 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
