90° Fitting obstruct nitrous flow?
Old Apr 26, 2005 | 08:30 PM
96speed's Avatar
The way I'm thinking about setting up my nitrous solenoid would use a 90° fitting on the end of the solenoid. Do I need to stick with a straight fitting where the N2O is discharged, or does it matter at 1000+ psi?
Ryan
Old Apr 26, 2005 | 09:25 PM
Ryan94ZA4's Avatar
Re: 90° Fitting obstruct nitrous flow?
You'll be fine with the fitting. Flow won't be as obstructed there as it will be at your little nitrous jet...
Ryan
Old Apr 27, 2005 | 12:13 AM
Ryan94ZA4's Avatar
Yeah, yeah..... Maybe he's spraying his supercharged engine.
Old Apr 27, 2005 | 10:37 PM
96speed's Avatar
I'm an idiot. I thought I was in the N2O forum when I posted this.
FWIW: Talked to NX today and they recommend against it, although the nozzel creates a 90° turn . However, I found a way to keep a simple straight discharge fitting.
Brook:
Ryan
Old Apr 28, 2005 | 10:05 PM
96speed's Avatar
Stock ported, 100, 125, 150....no more than 200.
Ryan
camaroguy50613
May 27, 2016 09:00 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
