video , stock bottom end and 200 shot 10.26..looses roof
Re: video , stock bottom end and 200 shot 10.26..looses roof
Wow!
I had a 85 Vett and those roofs are screwed in at the front with a screw in each corner. I think from memory they just push onto some pins at the back.
That would take some force to rip that off!
Thay are Acrilic and not cheap to buy either!
Holly **** just about summed it up man good video.
the frame is held in place with 2 bolts in the front and 2 bolts in the back, then the top cover either fiberglass or lexan ( mine is lexan) are glued or urathaned to that frame work. The lexan seperated from the frame work. It landed in the grass and was unharmed, it's already urathaned back on.
Fast and Furious ? WTF ???
thanks GLE and morrow,
now it's your guys turn to lay down a PB. I did let off right before the ET line so the ET will not change much if any on a full pass, the MPH will go to 128-129, but we'll see as the next time will be with the 700 trans back in.
Mike
Mike
That would make me nervous.
