Limited slip additive, is it needed with Royal Purple?
Old Apr 20, 2005 | 09:42 PM
LS1_03's Avatar
I'm currently swapping out my 2.73s for 3.73s. Normally you would put regular oil in and add some limited slip additive. Is the additive needed with Royal Purple Synthetic oil?
Old Apr 20, 2005 | 10:52 PM
Bandit 1's Avatar
Re: Limited slip additive, is it needed with Royal Purple?
I do not believe you need to add an additive with Rpurple. But you do with Red line.
Old Apr 20, 2005 | 11:27 PM
Pro Built Automatics's Avatar
Unlees it specifically says it is in their fluid, I would add the GM posi additive.
Old Apr 21, 2005 | 07:53 AM
94Zpower's Avatar
I think that RP does mention that it is in the fluid but when I put it in I also added the GM additive and so far so good for the 2nd year running.
Old Apr 21, 2005 | 08:22 AM
LS1_03's Avatar
Thanks a bunch, guys. I'll relay the info to my friend who's doing the swap. He's got additive and regular oil if it doesn't work out.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
mjcent922
Jul 27, 2002 12:42 PM
