issues using studs on block to bellhousing bolt holes?
Old Apr 19, 2005 | 08:06 AM
v7guy's Avatar
Was wondering if it would be possible to use studs in place of bolts in the block to bellhousing holes, maybe it would make it easier to line things up?
Pulling the tranny here in an hour or so to replace the rear main, so I figured it might make things easier in the future and on reassembly
Old Apr 19, 2005 | 09:32 AM
OBE1 95Z28's Avatar
Re: issues using studs on block to bellhousing bolt holes?
The bell housing lines up easily, there's 2 pins to get it lined up. If you're installing the tranny/bell housing simultaneously, I'd suggest you separate the two. The tricky part is getting the tranny to line up on the bell housing.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Catmaigne
Dec 25, 2014 12:16 PM
Joes96z
Dec 13, 2014 07:48 PM
