Purchasing procharger pulleys
Old Apr 18, 2005 | 02:54 PM
ProchargedLT1's Avatar
Is it better for an individual to call ATI directly or to go through one of there distributors for a good price on a pulley?
thank you
Old Apr 18, 2005 | 03:56 PM
Jeff 96 SS's Avatar
Re: Purchasing procharger pulleys
Call Lonnie http://www.outlawpontiacdragseries.com/portal.php
He is great he will talk out your combo with you and get the perfect size pully for your desired boost.
Jeff
96 SS BLOWN
96 TA 396 D1
Old Apr 18, 2005 | 03:58 PM
Jeff 96 SS's Avatar
oops wrong link http://www.lonniesperformance.com/
Jeff
96 SS BLOWN
96 TA 396 D1
Old Apr 24, 2005 | 11:31 AM
mzgp5x's Avatar
I've tried direct. They don't take direct orders. Wish they had a parts listing on their web site. I've had distributors get it wrong for me. Quite a hassel.
Old Apr 24, 2005 | 09:34 PM
KS91Z28's Avatar
I assume you're talking about ProCharger? They sell parts direct all the time.
Old Apr 24, 2005 | 09:58 PM
hellostop's Avatar
I've got some 12 ribs if your interested
Steve
Old May 14, 2005 | 05:46 PM
Acct 23749's Avatar
Steve
I am...let me know
Old May 14, 2005 | 10:01 PM
SteveLT1's Avatar
when i called ati for a pulley for my p600b,they said they only have 12lb ones. is anyone using a 15lb pulley,or know where i can get one for a p600b.
Old May 18, 2005 | 12:43 PM
tubby's Avatar
word of caution when talking in terms of #'s. for example if you want 12# pulleys is it a stock motor or say a 383 w/ big AFR heads. this can change things quite a bit.
Old May 18, 2005 | 12:47 PM
SteveLT1's Avatar
im not sure if my signature showed up but... its not a stock motor...ati rates their pulleys on a stock motor...i used to have the 8lb pulley i believe that was a 2.85., the 12lb pulley is a 2.65, the 15lb pulley is a 2.55? is this correct?
Old May 18, 2005 | 04:51 PM
BADST95's Avatar
Smile Re: Purchasing procharger pulleys
I have a virtually brand new 430 mm 12 rib belt (used for 3 dyno pulls) for sale. The part number is: DB430|12. $40.
Thanks,
Mitch
Cmunter14@hotmail.com
Old May 18, 2005 | 10:28 PM
Ponyhntr's Avatar
ATI sells parts and kits retail, you don't have to go through a dealer; howerver your dealer can get a better price for you.
If calling direct, try to have your serial #. I've found out it makes things a LOT easier. Also, if you want to up the boost, but you don't know what the serial # is, you will need to know the SIZE (in inches) of the pulley, how much boost that one makes, and how much boost you want with the new pulley. The tech will then be able to get you the correct pulley.
BTW: That's actually a 43.0 inch belt, not 430mm. The part # should be DB430I-12
Old May 18, 2005 | 11:03 PM
SteveLT1's Avatar
i called 2x... the first person i got.. said a 15lb would put it close to overreving..at 6400 rpms or somethin...then someone else said to give me a 12 lb pulley..so baiscally..i doubt theyd sell me a 15 now..i think they used 2 in the past...anyone have info on this?maybe i'll just call em..
Old May 18, 2005 | 11:23 PM
agrsiv95's Avatar
I nuked my old P600B twice with the 2.55 pulley and a 7.00 crank and was only going to 5800 rpms.
J
Old May 18, 2005 | 11:26 PM
SteveLT1's Avatar
thats what i needed to know...15lb isnt for me then heh
