Opinions Needed From All N2o Users!
Old Apr 17, 2005 | 01:18 AM
Black1995Z's Avatar
Talking Opinions Needed From All N2o Users!
Stock Motor
Stock Fuel System
Safe to run a 150 wet shot? Yes or no?
I see a lot of threads about it, but its all mixed. I just want to see some straight answers. Right now I'm running a 100 and its fantastic.
Old Apr 17, 2005 | 02:26 AM
breakmyfootoff's Avatar
Re: Opinions Needed From All N2o Users!
I would say no, unless you are planning on rebuilding soon anyway. 150 on a stock fuel system is right at the point between pushing the limit and passing the limit, you might get away with it, you might not. I say don't press your luck. When I still had nitrous and the stock fuel system on my car my fuel pump would give out with a 125 shot becuase I already had cam, headers, etc. Having those other mods plus the 125 shot required more fuel than the stock pump could provide and it was a new pump.
Old Apr 17, 2005 | 10:21 AM
Mr_Bond's Avatar
Racetronix makes a great plug n play fuel pump
Old Apr 17, 2005 | 12:18 PM
Black1995Z's Avatar
what size and how much?
Old Apr 17, 2005 | 12:36 PM
Here is the racetronix kit
http://www.racetronix.com/Racetronix..._Pump_Kit.html
Old Apr 17, 2005 | 01:11 PM
Black1995Z's Avatar
Thanks for the link! Bookmarked it
Ok so, basically 150 isnt safe. How about a 125?
Old Apr 17, 2005 | 03:36 PM
LameRandomName's Avatar
Originally Posted by Black1995Z
Stock Motor
Stock Fuel System
It's been literally 20 years since I last used nitrous, although I am planning to get back into the game in a big way.
In my experience, it's not the 150 shot that will hurt you. There are several folks running a 200 shot on a stock engine.
What's important is the support systems.
My thoughts...?
A Mallory 110 and FPR with return line, hooked to a dedicated fuel cell on the order of 1 or 2 gallons and proper programming. Also, either buy a nitrous controller or retard your timing about 8 degrees.
That's not what I would do on MY motor, but that's only because I'm planning on a much more sophisticated system than what I ran 20 years ago when I was just trying to figure out what Scott S. was doing with his Monza.
Old Apr 17, 2005 | 09:13 PM
jre97's Avatar
I have been running a 150 wet shot for a while safely on a stock fuel system and my friend that I bought the car from ran it for two years before that. The first thing we did was install an air/fuel ratio gauge and tuned it to stay safely on the rich side and kept increasing jets until the 9th light started to fade at a 175 shot after that you need a fuel pump in my opinion.
Old Apr 17, 2005 | 11:11 PM
Black1995Z's Avatar
what color is the wire on the O2 sensor that you need to tap into for the A/F ratio gauge?
Old Apr 18, 2005 | 10:12 AM
Nitro Dave's Avatar
We tell our customers anything over a 100 shot to upgrade the intank pump.I know some people spray 150 on a stock car and stock pump.
The best way to know is to have a machanical fuel pressure gauge or put it on a dyno with the air fuel hooked up.
Its better to just spend the 125 for a new walboro pump and move on.
Dave
Old Apr 18, 2005 | 02:21 PM
Black1995Z's Avatar
Thanks Dave.
Is an A/F ratio gauge worthless? Ive been reading a lot and I have heard it is, but this is from non-n2o users. Is it worthless for us too?
Old Apr 18, 2005 | 02:57 PM
Serene's Avatar
Thanks Dave.
narrowband is useless. wideband is one of the best things to have
Old Apr 18, 2005 | 03:08 PM
Black1995Z's Avatar
whats the difference?
okay, I just installed my a/f gauge and the gauge just goes back and forth. Sometimes it stays on rich. I found the purple wire from the o2 and cut it. I then stuck the wire in a butt connecter and crimped them. did i do anything wrong?
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jlo
Feb 3, 2015 09:41 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
