radiator material
Old Apr 7, 2005 | 08:03 AM
94307's Avatar
radiator material
Two types of radiators that I know about: aluminum and copper/brass. I hear that one is better than the other depending upon who I talk with. Basically, I want to know which will transfer heat the best. My other concern is paint that is normally applied to the copper/brass radiators (where aluminum is normally bare) and how that affects heat transfer.
Old Apr 7, 2005 | 10:12 AM
LameRandomName's Avatar
Re: radiator material
Well, Copper has a higher thermal conductivity (401 W/m.K) than Aluminum (237 W/m.K) and Aluminum (897 J/kg.K) has a higher heat capacity than Copper (385 J/kg.K).
I found those numbers on a quick google search and I won't pretend to know what they mean, but I do know this; copper weighs about three times as much as aluminum. Also, if you are buying a modern radiator design from someone like BeCool or Griffen, it won't really matter anyway; because the design improvements are where the "magic" is.
So... six of one, a half-dozen of the other...
My opinion...? Go with an aluminum radiator for the weight savings.
As to paint, well... I'd imagine that any barrier between the metal and the surrounding atmosphere will impede heat transfer, although I don't think it will make a huge difference. All things being equal, I'd say that the advantage goes to aluminum again.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
