Can an amp be hooked up to deck without using RCAs??
Old Oct 14, 2002 | 02:26 PM
naaz90's Avatar
i have an alpine CD player with only one preout. i have a 4channel amp pushing the 4 speakers, but due to the single preout i can only splice the RCA and run all speakers as "rears". So basically i cant fade back to front using the deck.
Can the amp be wired differently without using the RCAs, and give me control over all the speakers?
Old Oct 14, 2002 | 02:30 PM
naaz90's Avatar
Also if there is a different way, what would produce the best sound quality?
Old Oct 14, 2002 | 02:33 PM
97FormulaWS-6's Avatar
I can be done.. 2 ways, but SQ isn't really going to be great with either.
1st:
Get 2 LOCs (Line output Converters) Wire your HU speaker outs to them, then run RCAs from the LOC to the amps.
2nd:
Get a 4ch amp with "high" level inputs, and wire the speaker leads from the HU to that.
Neither are the ideal way to do it but those are your options with only 1 pre-out.
Mike
Old Oct 14, 2002 | 11:34 PM
naaz90's Avatar
i am guessing my amp has the high level inputs its pheonix gold 4300x. I figured thats how i do it. Thanks
Old Oct 15, 2002 | 05:45 AM
LS1 RULZ's Avatar
Sound quality wise, your best bet would be to add a 1/2 DIN EQ with it's own fader control.
You might also check at your local install shop to see if they have a "Dual Amp Balancer". This is simply an outboard fader control. Kenwood used to make them a while back. I don't know if they still do or not.
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
jackpawt883
Sep 10, 2015 08:53 PM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
