New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
93-97 hood FS & Hood Scoop
Old Mar 26, 2005 | 01:06 PM
97trans's Avatar
Hello this is a factory hood. A friend and I put on the hood scoop, with rifits(sp) and bondo. I know very little about body work, So i was going by what my friend was telling me to. It started to crack so I took the hood scoop off trying to fix it. It is to much work for myself. The hood has (12) 1 13/16 holes in the middle to help vent some of the heat. They are covered with tape for the moment. The hood scoop was purchased off ebay. I have some (2)SEM 39747 Multi-purpose Panel Adhesive and (1)SEM 39767 Problem Plastic Repair Material also. Purchased that from local dealer. I have pictures if anyone is interested. I would like to get $150 for everything. The scoop was $100+ and the glue was $80 and the factory hood was on the car. If someone knew what they are doing i'm sure it can be made to look great
Old Mar 26, 2005 | 02:22 PM
Kataklysm's Avatar
Re: 93-97 hood FS & Hood Scoop
You cut holes in the hood? That wouldn't help anything at all...it would just let water in cause it wouldn't be sealed correctly. Water + LT1 optispark = dead car.
Old Mar 26, 2005 | 03:49 PM
97trans's Avatar
actually there were no problems with water I had it on for almost 2 years the holes are under the hood scoop so as much water that gets into a ram air system will get into this one
Old Mar 26, 2005 | 07:36 PM
Kataklysm's Avatar
No water gets in with Ram Air, the box is sealed off, it's designed correctly. If water got in the MAF would be crap and then the engine would be full of water and be crap too.
Old Mar 27, 2005 | 12:36 AM
97trans's Avatar
Ok that was my whole point. You have not seen it so how are you going to comment on it.
Old Mar 27, 2005 | 10:48 AM
DiabloGT's Avatar
Im in kingston MA, so im close, how much for the ss hood( wait is it an ss hood?)? and send pics to hiphophomer2000@yahoo.com
Old Mar 27, 2005 | 04:12 PM
TedH's Avatar
How much for just the scoop? Pictures would be a big help...
Stephen68
Oct 16, 2015 03:50 PM
CARiD
Sep 30, 2015 05:44 AM
alliance12364
Sep 17, 2015 08:43 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
