99' Camaro
Old Mar 22, 2005 | 08:18 PM
teh no0b's Avatar
99' Camaro
I have a 1999 Camaro it's my first car i'm 17. It has alot of miles on it i'm talking almost 136k miles. Any suggestions on what I should do to tune it up? I am asking for a slightly used SS for my graduation in May from HS. Some common problems with it is a constant whistleing sound when the car is running high pitched it comes out of one of the exhaust pipe breather things half way down the exhaust pipe under the car. . also randomly just sitting at a stop light or w/e the battery power will suddenly drop to below the middle reader thingy and the headlights and console lights all dim and then you hear it go back up. . bout all I can think of any suggestions what to do?
Old Mar 22, 2005 | 09:44 PM
JJayzX's Avatar
Re: 99' Camaro
Do the usual. Plugs, wires and oil and filters, coolant. For the power issue check your battery and alternator and ground connections.
Old Mar 25, 2005 | 12:04 PM
fesgali's Avatar
Re: 99' Camaro
I get that same high pitch noise from under the car after a while, i don't get what it is.
belt, fluids, filters, plugs, wires, and whatever else needs to be replaced
Old Mar 26, 2005 | 09:20 PM
Chrisz24's Avatar
Re: 99' Camaro
My battery volts drop alot of times when I shift into Reverse but it has done it on the move at stop lights before, I try to minimize the amount of accessories I have on.
Old Mar 28, 2005 | 07:41 AM
Camabird's Avatar
Re: 99' Camaro
BAH! Spoiled!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
