Looking for suggestions on the best "bang for the buck" rotor...
Old Mar 21, 2005 | 11:12 PM
JasonD's Avatar
Admin Emeritus
Looking for suggestions on a good looking, dimpled and slotted rotor that performs well on the street as well as some light track duty.
I am doing the C5 upgrade on the front soon, and would like some suggestions from those who know. I don't want to spend my money on something that will crack or warp the first time I hammer it hard.
Thanks!
Old Mar 21, 2005 | 11:32 PM
ZaneO's Avatar
Re: Looking for suggestions on the best "bang for the buck" rotor...
I'd look for the Brembo blanks that have been slotted and cross drilled. Several companies out there do them.
Old Mar 21, 2005 | 11:36 PM
JasonD's Avatar
Admin Emeritus
I can check into that. Do you know if they are available dimpled from any company? I want the looks but I don't want the cracks.
Thanks.
Old Mar 21, 2005 | 11:38 PM
ZaneO's Avatar
I'm really not sure. *I* would go with the blanks, but I understand the bling factor too
Old Mar 22, 2005 | 12:41 PM
stereomandan's Avatar
Thanks!
PM bruecksteve. He has done the C5 conversion and has cross drilled/slotted rotors that are a GM part number. They are VERY inexpensive. I've also done the C5 conversion, but I wanted a plain rotor. My rotors were less than $20 each believe it or not, and they are GM rotors. Gotta love C5 rotor prices. You can see pictures of them in my webpage.
Dan
Old Mar 22, 2005 | 01:59 PM
WestCoast96Z28's Avatar
Try Tirerack and search for brakes for the Corvette:
http://www.tirerack.com/brakes/resul...perf&x=108&y=3
Looks like both EBC and Power Slot makes slotted and "dimpled" rotors, to give the look of cross drilled. Not exactly cheap, but EBC and Power Slot are good brands. I think Power Slot uses Brembo blanks??
I did some research recently on this subject since I'm doing the LS1 upgrade soon. I'm going Baer because Tbyrne has a good deal on Baer Eradispeeds and Hawks. Else, I would have done the Pro Stop (Power Slot with dimples).
Good luck.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
