FE4 Suspension
Old Oct 13, 2002 | 10:36 AM
holeshot's Avatar
Question FE4 Suspension
The later F-cars had an optional suspension package. This was listed as "Special Ride & Handling" Suspension with an RPO code of FE4.
Does anyone know specificaly what this package included and how it was different than the base suspension?
Thanks.
Old Mar 14, 2003 | 02:53 PM
95 Z/28 LT1's Avatar
Super Moderator
TTT
Anyone have any info on the FE4 setup?
Old Mar 14, 2003 | 03:00 PM
Larnach's Avatar
I thought that was the ZO6 suspension.
Old Mar 14, 2003 | 03:17 PM
Super Moderator
It is, but the Camaro/Firebird had its own version of it too
FE2 Suspension System Ride Handling
FE4 Suspension System Special Ride and Handling
FE7 Suspension System Frt & RR HD
Those were suspension RPO codes.
I was wondering what each entailed as far as springs, shocks, etc.
Old Mar 18, 2003 | 05:33 PM
Super Moderator
I guess no one knows what the FE4 suspension includes.
Old Mar 18, 2003 | 05:55 PM
greenZ94's Avatar
Why don't you guys post this in the AutoX & RR section
I would figure that there should be a knowledgable suspension junkie over there who could give you an answer.
Old Mar 18, 2003 | 08:06 PM
stik6shift98's Avatar
nope.....i heard of a couple weird names but never fe4.....
Old Mar 18, 2003 | 10:32 PM
BoscoZ28's Avatar
Nope, cant say I've heard of it either. Only thing I can think of is the 1LE.
Old Mar 18, 2003 | 10:43 PM
BoscoZ28's Avatar
HHmmm, after a little research, looks like maybe its more of a firebird/transam option, I found a list of part numbers and ran across this, part numbers for springs
22132887 / 22132889
(ZR, HS) 1998 Camaro Z28 1LE
(ZM, TJ) 2000 Trans Am WS6 FE4
(ZM, TJ) 2000 Trans Am FE2
(ZL, TH) 2000 Formula NHRA FE2
Old Mar 19, 2003 | 08:03 AM
Super Moderator
Yeah, I saw these springs that were from a WS6 TA Vert at a bone-yard, and they were supposedly from a FE4 car.
What I wanted to know is, if they would be any better than say, stock LT1 or LS1 Z28 springs.
I wonder what the spring rate for them is?
Old Mar 19, 2003 | 08:08 AM
BoscoZ28's Avatar
Im Sure they are. It looks to be like its the equivilent of a 1LE, in which the front springs are 360lb/in and the rear is 130-170lb/in (progressive)
Old Mar 19, 2003 | 12:53 PM
where can you get fe4 stuff and how much is it.....????
Old Mar 19, 2003 | 06:53 PM
Lasombra52's Avatar
A little off topic.
I have the RPO FE2.
1998 Camaro Z28. It says Touring Car Suspension for the description. (I have all the info on my car from GM)
I think the FE4 is an upgraded suspension for WS6's. But I'm not sure.
Old Jan 14, 2005 | 10:55 AM
NBred94's Avatar
Re: FE4 Suspension
Resurrecting this old thread, one thing I found doing research is that the part numbers for 1LE and FE7 front lower control arms are the same. I'm about to order some, so I will report back what they look like.
Old Jan 15, 2005 | 09:58 AM
Z28Nut's Avatar
Re: FE4 Suspension
I have the FE4 option on my '94. I tried to find a stiffer spring through GM (1le) and can't go aftermarket lowering spring due to end of driveway clearance. If I recall correctly, the FE4 and 1le were very close if not the same spring. Also WS6 came up alot and the orig. salad shooter wheels have WS6 cast on the inside of the wheel (do they all have that?). With Hotchkiss LCAs, PHB, sway bars frnt & rear and Edlebrock TA, it's a very stiff and unforgiving ride. This is with orig. shocks. With the beefier sway bars, the car feels like it's on a rail around corners. I couldn't get spring rates but from the cross-reffing they are about the stiffest factory spring GM made.
