f/s 1991 z28
Old Mar 16, 2005 | 11:25 PM
slow_roc's Avatar
f/s 1991 z28
i have a clean 91 white z28 camaro with tan interior for sale semi built up but still needs a lil finishing, it has 99,998 miles with a 406 small block chevy with the Holley Stealth Ram TPI intake and 30lb Accel injectors, Holley 255L fuel pump and holley adjustable fuel pressure regulator, Maxi cool oil cooler, SLP 1 3/4" headers, 3in" Flowmaster exhaust out back( has a exhuast leak). Th350 trans built up, with TCI 2800 stall, Sphon adjustable torque arm, also Sphon 3" driveshaft, lakewood lower control arms, and panhard rod. Sportsman II stage two ported heads with summit 1.6 roller rocker arms, Hydraulic Roller Comp Cam grind number CS 280H-R10 (224 @.05 .525I .525E LSA 110 with 1.6 roller rockers lift is .565), Accell wires and Bosch plugs. No a.i.r no a/c, no cats, newer factory cd player included. Also B&M star shifter with New radiator, new starter, new battery, some stainless steel braided lines on oil/trans cooler Also new rear rotors and pads, with new Chevy valve covers, timing chain cover and oil pan asking 3500 the only thing about the motor i think the guy that had it befoer didnt break it in right there some blow by maybe rings but then friend of mine said that i mgiht have the vaccum lines hooked up wrong so idk i broke as a joke and need money for school so ... that why im selling it heres a pic (sorta crappy) http://geocities.com/k2_kid2004/01010038.JPG
Old Jun 14, 2005 | 10:50 AM
kandied91z's Avatar
Re: f/s 1991 z28
ever sell this?
Old Jun 14, 2005 | 05:29 PM
slow_roc's Avatar
Re: f/s 1991 z28
currently being put back together as a 305 700r4 car (stock except header and exhaust ) hopefully have a lil more luck selling it that way and then selling off the performance parts
Old Jun 14, 2005 | 05:53 PM
kandied91z's Avatar
Re: f/s 1991 z28
well i'm looking for one but it either needs to be a reliable driver with minor body work needed or a straight/rust free body to make me interested. let me know what you have, what you can do without and whatnot and if you have any decent pictures get back to me.
we aren't too far from each other so i could drop by and take a look if your wanting to sell it. let me know.
Old Jun 17, 2005 | 12:19 AM
2001 B4C's Avatar
Re: f/s 1991 z28
i am EXTREMLY intrested in a trade.... must i emphasize EXTREMLY?
http://web.camaross.com/forums/showthread.php?t=375847
i need it for a project, and i need to get rid of the IROC..
A's 91 Z28
Jan 11, 2015 10:58 AM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Jon657
Jul 19, 2002 07:51 PM
