obd1 to obd2
Old Mar 12, 2005 | 06:42 PM
jadams94ta's Avatar
obd1 to obd2
can you just get a obd2 computer and put it in a obd1 car? will it hook up of do you have to do something to the harness
Old Mar 12, 2005 | 07:35 PM
Highlander's Avatar
Re: obd1 to obd2
all you have to do is change knock sensors
Old Mar 13, 2005 | 02:16 PM
LiT1_up's Avatar
Re: obd1 to obd2
What about the rear 02s?
Old Mar 13, 2005 | 02:25 PM
jay_lt4's Avatar
Re: obd1 to obd2
obd1 to obd2??? are you sure you dont mean the other way around
obd2 to obd1 all you do is change the knock sensor
obd1 to obd2 many changes, the obd2 pcm uses a crank sensor, rear o2 sensors, different timing cover crank hub plus many other differences
Old Jul 3, 2005 | 08:49 PM
Highlander's Avatar
Re: obd1 to obd2
The crank sensor is only used on 97s.
Sep 6, 2015 03:10 PM
Aug 24, 2015 06:41 AM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Pullngz
Jul 26, 2015 05:55 PM
