Amplifier installation
Old Feb 22, 2005 | 11:29 PM
thefox1's Avatar
I got a 4 channel amplifier and hooked everything up today. On channel 1 and 2 I have 2 9x6" speakers and on channel 3 and 4 I have some small subs. I hooked the amplifier to the radio with rca cables. The only problem was after it was all set up, I was not able to configure the amp to send much bass to the subs, what should I do at this point? Do I need low pass filters on the sub connections? The amplifier is a Boss Rip 796.
Old Feb 23, 2005 | 07:07 AM
SSactionLs1's Avatar
Re: Amplifier installation
boss amps are a joke man. If it doenst have a built in xover you are somewhat screwed
Old Feb 23, 2005 | 04:12 PM
thefox1's Avatar
Dude, I ain't asking if boss amps are good or not, frankly I don't car bc this amp was very cheap and I did not have much money to put on it. And yes, it does have an x-over but it still seems to be letting pass too many highs.
Old Feb 23, 2005 | 04:52 PM
LS1 RULZ's Avatar
Chances are the x-over only has a 12dB/octave slope. This is NOT a brick wall filter that cuts everything off at a certain point. The highs will still be audible but at a lower level.
Old Feb 23, 2005 | 06:54 PM
thefox1's Avatar
This is what my instruction booklet says about blocking the high's: "use a wire coil inductor to block high frequencies from the subfoower". Do you know what they are talking about?
Old Feb 23, 2005 | 07:07 PM
LS1 RULZ's Avatar
A coil (or choke) connected in series with a subwoofer is only a 6dB/octave filter. Also called a 1st order passive low pass filter. This is even shallower than a 12dB/octave slope. Crossing over a subwoofer passively is not a very good way to go. An active x-over is the way to go when crossing over a sub.
Old Feb 24, 2005 | 01:24 AM
defensive eh
Old Feb 24, 2005 | 10:17 AM
thefox1's Avatar
defensive eh
yep
Old Feb 24, 2005 | 10:20 AM
thefox1's Avatar
Tnx for the info, I'll have a look at that. Btw I see you have boston acoustics for speakers, how do they sound in a car? I went a while back to hear some home theater boston acoustics and thought they sounded amazing!
Old Feb 24, 2005 | 10:57 AM
LS1 RULZ's Avatar
They sound great! WAY better than the POS Infinity speakers they replaced.
Old Feb 26, 2005 | 09:05 PM
SVWHAT's Avatar
I'm running MB Quarts in my front doors with one 10 inch Sub. If I was you try amplifing the front doors instead of the 6x9's which I'm guessing are sitting on the back hatch area or you cut them into the sides. When you go to a concert or movie the sound comes from the front not the back. Trust me it is a much better way to go even if the front door speakers are factory oem.
Nov 18, 2023 07:21 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
phatbasslines
Jan 13, 2015 05:03 PM
Z28STYLE23
Aug 17, 2002 07:40 PM
Highlander
Aug 9, 2002 02:30 AM
