Gauging Interest: 95 383 TA *Super Clean*
1995 Pontiac Trans Am. 6-speed Dark Green with Tan Leather interior. Fully optioned.
Air Conditioning
Power Steering
Power Windows
Power Door Locks
Power Antenna
Tilt Wheel
Cruise Control AM/FM Stereo
Single Compact Disc
Premium Sound
Dual Front Air Bags
ABS (4-Wheel) Leather
T-Bar Roof
Rear Spoiler
Premium Wheels
Car has been meticulously maintained. Best of the Best. Non-Smoker. I lost my privileges to my garage, and car now cannot stay outside. Originally the car was being built for a weekend only car. Now that I don’t have a garage anymore, I don’t like it staying outside. I am looking for something a bit more tame, and that could be used as a daily driver. Mobile 1 oil since day one, changed every 1500mi. Car is EXTREMLY Clean. Price is Negotiable Contact at Deenasty83@comcast.net for pics or call (415)740-9595 if you have any questions. Car will be smogged before sale. Car only has 44k Original miles. 7k on the new motor. This motor was actually built out of seperate engine block, not original, so dont think the original motor failed. I have full documentation for the vehicle, and 28k in receipts.
Motor:
- 383 Stroker (10.5:1 comp) JE Rings (4.030 Bore), Block has been bored 0.30 over, 68cc Dish Low comp, 4340 6” Rods, Comp Cam 1.6 Pro Magnum Rockers (7/16 Stud), 4130 Chromoly Pushrods (.80” wall, 7.200” length), Stock Replacement Lifters. Scat 4340 Crank. (Assembled by Colma Pontiac GMC Dealer)
- TPiS/AFR 190cc LT1 style head. 2.02/1.65 valves, 3 angle valve job, AFR guideplates 54cc chambers. .650 rated Double Spring, Titanium Retainers,locks, Full CNC Port
- TPiS ZZX Cam 240/240 .595/.595 112 LSA
- Mellings High Volume Oil Pump
- LT4 Manifold
- SVO 30lb Injectors
- 52mm BBK TB (Brand New)
- Graphite LT4 Valve Covers
- AC Delete Pulley (I have the AC for the Car)
- March Underdrive Pulley
- CSI Electric Water Pump
- Accel Adjustable Fuel Pressure Reg.
- New Opti, o2’s, MAP, TPS, IAC,
- All new gaskets, no leaks at all!
Exhaust:
- 1 ¾ Steeped to 1 7/8 Stainless Steel Kook Long Tube Headers with EGR and AIR fittings. (brand new)
- Kook 3” Y-Pipe with two High Flow Magnaflow cat’s (Brand new)
- 3” Borla Catback
- DMH Electric Cutout (4 year warranty)
Suspension:
- Front QA1 Coilovers, with QA1 Springs (Brand New)
- Competition Engineering Rear Shocks with 1” Drop Springs
- 1LE front sway Bar
- Spohn Torque Arm (Chassis Style) with Poly Bushing, and DriveShaft Loop
- SLP Subframe connectors (Brand New)
- BMR Extreme Duty rear sway Bar. Fully Adjustable to allow for suspension preload. (Chromoly End Links)
- Hotchkis Lower Control Arms (poly)
- Spohn LCA Relocation Brackets
- Poly Mounts Throughout.
- BMR Chromoly Strut Tower Brace
DriveTrain:
- Centerforce Flywheel (Balanced)
- Custom Built Clutch built by Pacific Clutch
- Balanced Stock Driveshaft
- Moser 12 Bolt, 4:10 gears, Heavy Duty posi, Heavy Duty Cover, 33spline axels, 1350 yolk, ABS. (Only 1000 miles)
Appearance:
- Suncoast Creations WS6 style hood. (Factory Ram Air Box)
- Black Racing stripes, with “Ghost” Checkered Flags in the stripes.
- Blacked out turn signals
- Brand New 18” Black Z06 Motorsport wheels: 275/35/18 up Front 285/35/18 Nittos outback (Brand new)
- 1998-2002 Rear Tail Lights
- WS6 Rear Badge
Stereo:
- Pioneer DEH-8400MP (MP3 WMA) (with Warranty)
- Optima Yellow Top (Warranty)
- QLogic Box (Matching color interior Plastic Cover)
- Two JL AUDIO W3 12”
- (4) Pheonix Gold 6.5”
- (2) MB Quartz Tweeters (Warranty)
- (2) Pioneer 6x9
- JL 500/1 Amp for Subs
- JL 300/4 Amp for Highs
- Pheonix Gold X-Over
Ignition:
- MSD Digital 6 Ingnition (brand new)
- MSD Blaster Coil
- Taylor 10.4 mm Spark Plug Wires (brand new)
- Bosch Platinum +4 Spark Plugs (brand new)
Cooling:
- Hypertech 160 Thermostat
- Manual Fan Switch
- Brand New Factory Radiator (Lifetime Warranty)
Others:
- Hurst Line Lock
- ARP 12pt Header Bolts
- Tuning done by FFP (Force Fed performance) (390rwhp through a catted y-pipe and a 12bolt)
- 5” Autometer Carbon Fiber Tach with Shiftlight
- AC Delete
- Summit Vacuum Canister
- K&N Filter in Factory Ram Air Box
- Painted Accessory Bracket, and Alternator (Gloss Black)
- B&M Ripper Shifter
- Viper Alarm
18k as is, price is negotiable without stereo system.
Air Conditioning
Power Steering
Power Windows
Power Door Locks
Power Antenna
Tilt Wheel
Single Compact Disc
Premium Sound
Dual Front Air Bags
T-Bar Roof
Rear Spoiler
Premium Wheels
Motor:
- LT4 Manifold
Exhaust:
- 3” Borla Catback
Suspension:
DriveTrain:
Appearance:
- WS6 Rear Badge
Stereo:
- (2) Pioneer 6x9
Ignition:
- MSD Blaster Coil
Cooling:
- Manual Fan Switch
Others:
- Hurst Line Lock
- AC Delete
- Viper Alarm
Campbellb48
Jul 5, 2015 06:31 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
