New to drag racing *help*
Old Jan 30, 2005 | 07:26 PM
thelastz28's Avatar
Exclamation New to drag racing *help*
I have a 2002 Camaro Z28 A4. What is the way to race automatics? Overdrive? or all 4 gears? Please help, Thanks.
Old Jan 30, 2005 | 08:48 PM
LS1_03's Avatar
Re: New to drag racing *help*
After your burnout, leave it in 3rd(D). Reason: Doesn't matter if it's in OD or D. But, if you leave it in D the engine will help slow you down after you cross the stripe.
As for launching, find a backroad and practice different launch RPMs.
Old Jan 30, 2005 | 10:35 PM
Capn Pete's Avatar
Like he said, put 'er in Drive and GO! "Manually" shifting your automatic will only help (with electronically controlled trannies) in a few circumstances. Get a programmer if you need to raise/lower the shift points.....shifting at just the right time has gained/lost me ~.2 seconds in the 1/4 mile before.
Old Jan 30, 2005 | 11:00 PM
thelastz28's Avatar
Exclamation Re: New to drag racing *help*
D or OD doesnt make a difference in speed? Thanks.
Old Jan 30, 2005 | 11:13 PM
Stephen 87 IROC's Avatar
Theoretically the tranny will keep the line pressure higher while in D than OD but I can't find any proof. If the car is set up properly, you'll never use OD in the 1/4 mile. You shouldn't be using OD in the 1/4 mile anyway because the OD gears are small and weak.
Old Jan 30, 2005 | 11:22 PM
thelastz28's Avatar
Thanks for all your help guys.
Old Jan 31, 2005 | 07:35 AM
Capn Pete's Avatar
I've heard the same thing, but I've tried running in both D and OD, and never seen a difference on the time slip that I could credit to that theory.
As far as running into 4th gear in the 1/4 mile, I've never hit it (yet) even running 4.10 gears. Not until you're running upwards of ~120 mph do you need to look at ways of staying out of 4th (higher rev limiter, bigger tires, or taller gears than 4.10) .
Old Jan 31, 2005 | 07:08 PM
thelastz28's Avatar
Thanks, one more question. Why do they burnout before a race?
Old Jan 31, 2005 | 10:51 PM
Capn Pete's Avatar
For guys with slicks, it's real important to heat them up so they'll stick.....the hotter the rubber gets, the stickier it gets, and sticky = traction.
You will see a lot of guys warm up their street tires too (I've done it with my car and seen positive results), but as a rule, street tires don't get any stickier when they're hot.....it's just a beneficial sometimes to clean them off before you run. With the tires I'm running now though, it did actually help to warm them up.....I cut a 1.92 60' time with my Hankook's!! Track prep was awesome that day though.
Old Feb 1, 2005 | 03:28 PM
00ls1's Avatar
also just to help in first gear your gonna have to hold yourself back from puttin the pedal to the floor... traction is everything out of the hole just remember that
Old Feb 1, 2005 | 05:29 PM
thelastz28's Avatar
Thanks again. But, first gear? I hava an A4 2002 Z28.
Old Feb 1, 2005 | 06:30 PM
00ls1's Avatar
well you still have a first gear in that auto.. haha i know what you mean but you can spin those tires almost as easily as us m6 guys so out of the hole feathering that throttle will be important
Old Feb 2, 2005 | 09:29 AM
five7kid's Avatar
Up to a point. That point is determined by track temperature (which is why you often see a crew member out there with a pyrometer). Most non-professionals get their tires too hot. When I asked the manufacturers about the burnout required for DR's (BF Goodrich) and Quicktime Pro DOT's (Hoosier), the response was the same: "Don't do a burnout. Just turn the tires enough to clean them. The traction is in the compound."
Old Feb 3, 2005 | 08:18 PM
thelastz28's Avatar
Good tips, I'll try them when I go to the track.
Old Feb 4, 2005 | 08:26 PM
SFB767's Avatar
Here's the best way to drive your A4 at the track.
First of all, don't manually shift an automatic transmission, you're just wasting your time and you may damage the transmission.
Your very first pass
1. Make sure your traction control is turned off
2. Totally avoid the water box and don't do a burnout
3. When the light turns green, just take your foot off the brake and leave at idle without spinning, just to get a feel for how things at the track work
When you're comfortable launching hard
2. Drive up to the tree and stage
3. As soon as the 2nd stage light comes on, put your left foot on the brake and press the acclerator to about 1,000-1,000 RPM with your other foot
4. As soon as the yellow light flashes, take your foot off the brake while leaving your right foot in the same position and you'll feel the car bounce forward
5. As soon as you feel your tires grab traction (this could be right away or after minimal wheelspin) just floor it, point the car straight and hold on
It will take practice. I used to always get 2.3-2.2s, but since I've practiced launching, I can now get 2.1-2.0s without even burning out.
Good luck at the track.
