Free mods
Old Jan 30, 2005 | 01:08 PM
cc89formula's Avatar
Free mods
alright im just wondering what else i can do to my 89 Formula L98 without spending some real cash. Mods so far are
modded air box, K&N, descreened MAF, TB airfoil, Flowmaster exhaust without cats and threw in a cut out for the track, 700R4 out of an 89 vette with shift kit (dont know if the vette tranny is any different it was already in the car)
Any suggestions? I live in Texas and emmisions arent really going to be a problem.
Old Jan 30, 2005 | 01:49 PM
stanghunter211's Avatar
Re: Free mods
You could take the top end apart and port the hell out if it. That should give you a little more breathing ability up top. Other than maybe removing the A/C and what not to lighten the drag on the motor, I don't know of too many more "free" mods that can be done, that will increase power output.
Will
Old Jan 30, 2005 | 02:14 PM
95redvert's Avatar
Re: Free mods
"Free" or cheap mods
-Remove cat
-delete EGR
-relocate MAT sensor
-remove air box, replace with cone filter
-descreen MAF
-port MAF
-increase timing
-tb airfoil
-tb coolant bypass
-increase TPS voltage
-remove A/C components, run smaller belt
-headers
-afpr
-port TB, Plenum, Runners, Manifold, and Heads. Gasket match.
-new plugs, wires, cap and rotor
-sticky tires. (TPI motors make torque, take advantage of it)
-shift kit
Thats all I can think of right now. Hope it helps.
Oh one more thing. You may have read it but I have a issue of High Performance Pontiac where they did a trackside TPI tune up on a stock 1988 GTA with a L98 and 700R4. They added et streets, increased timing to 13*, added a afpr, removed the air box and added a cone K&N, descreened the MAF, ported the plenum walls, and added a tb air foil. They went from a stock run of 14.79@94.68 to a best of 14.19@96.88mph. They feel that if they had more time to play with the timing and fp, plus a track that wasnt so sticky they could have gone 14.0 or a 13.99 even. According to the article fresh glue was laid during the test and tune at Raceway Park, it was a bit more rolling resistance than a stock car could handle. Not bad for a cash outlay of $300 and one afternoon at the track.
P.S. I have the mag here in front of me that's how I remebered it all! LOL!
Old Jan 30, 2005 | 03:49 PM
Colin91Z's Avatar
Re: Free mods
You could also bypass the coolant running through the throttle body. That will keep the intake much cooler and might net you a few ponies
Old Jan 31, 2005 | 08:59 AM
teke184's Avatar
Re: Free mods
while you're doing the TBB put in a lower thermostat
i did the "gut the airbox" 1 step farther and gutted out some of the restrictions in the intake Y.
not sure if the formula intake is the same as the camaro... so maybe that won't work
Old Feb 1, 2005 | 10:43 AM
raul.garcia's Avatar
Re: Free mods
-Remove cat
-delete EGR
Can't do either in Texas (well, not in Houston)
Works better if the cone is fed outside air.
-descreen MAF
-port MAF
A descreened MAF will flow more than the TPI can use, no need to port the MAF.
45°. 0r 90° bends in the air path cause severe turbulence which the screens minimize.
How do you increase the voltage other than adjusting for max voltage without loosing the min voltage of 0.54?
Old Feb 1, 2005 | 12:06 PM
Tru2Chevy's Avatar
Re: Free mods
Don't forget weight reduction
- Justin
Old Feb 1, 2005 | 01:37 PM
95redvert's Avatar
Re: Free mods
If you can't do it in Texas then I'm sorry.
Yes it will work better with outside air, but not everyone wants to cut up there car. You have to cut the air filter tray for it to work properly.
A descreened MAF will not flow more than the TPI can use. Removing the screens increases throttle response and lower's et, it's been proven many times!
Increase the min .54 volts. Myself and three others have done it here, all saw improvements in et. I went from 14.93 to a 14.80 by increasing voltage to .60. Runs were made on the same day within an hour of each other, so no change in weather or anything else.
Old Feb 2, 2005 | 07:07 AM
Formula350ks's Avatar
Re: Free mods
I don't know if cutting up the stock air box will net you the same effect but I picked up a cheap CAI pipe at like Autozone or some store don't remember where meant for a civic. Its just a straight chrome pipe with a bend at the end. It went right on the MAF and goes right to where the stock air box was. slapped a cone filter on there and noticed a SOTP difference in throttle response. Also don't forget about an MSD or accell coil and HEI module while you are doing the ignition upgrades.
Old Feb 5, 2005 | 12:35 AM
Re: Free mods
so what does everyone think about going from a 3.23 rear end to a 3.42? ive got one laying around here so i figure why not pop it in right? what kind of time differences do you think that will make?
Old Feb 5, 2005 | 12:46 AM
90rocz's Avatar
Re: Free mods
Maybe a couple of tenths, depends. But it's a better gear than the 3.23 for racing and on the street it's better than 3.73's..for gas.
Old Feb 5, 2005 | 02:25 AM
mako350Z28's Avatar
Re: Free mods
My car must be a freak, because I have only done a few mods listed and it runs in the area of stock LT1's (13.8x@100.2x mph).
Old Feb 5, 2005 | 07:26 AM
Re: Free mods
Do you have the 9-bolt rear end? If so you don't have 3:23's unless they are aftermarket.
Old Feb 5, 2005 | 03:20 PM
97LT1M6's Avatar
Re: Free mods
I don't think it'll be much of a difference at all to be worth doing..
Old Feb 5, 2005 | 04:07 PM
Re: Free mods
umm thats a good question...its the stock rear end, i dont really know what came in these cars, i thought it was a 10 bolt but ive never got under there to find out. and i know they arent aftermarket, everything ive found tells me they are 3.23s though
