Black Z06 motorsport wheels are gonna be here tommorrow!
Old Jan 27, 2005 | 03:39 PM
AW/whiteZ-28's Avatar
I got em off ebay we'll see how good this ebay seller is when they arrive tomorrow
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
nevermind my ebay name it's a long story...
Old Jan 27, 2005 | 09:17 PM
cfdemarco's Avatar
Re: Black Z06 motorsport wheels are gonna be here tommorrow!
Cool...I got my black Z06's from the same guy on eBay this past summer...
BTW, just as a heads up, I had to get new longer wheel studs and use a 5/16th spacer to get mine to fit, using a 295 tire (2000 Trans Am)...the stock studs weren't long enough when using the spacer, so I got ARP studs which are longer and threaded all the way to the tip, whereas the stock studs are only threaded 80%
What tires are you going with?
Old Jan 27, 2005 | 09:46 PM
Zack's Avatar
pretty good price. I can get them for a lil under 600 bucks..thanks employee discount
Old Jan 27, 2005 | 10:10 PM
Well I have some 335/30/18 michelin pilot sports in the backyard. My friend has some on his mustang (same size rim) and they don't bulge out at all, but if they don't work, I got the tires for free anyway and I can sell em and get some 315's.
The front's I haven't decided yet my friends little brother is getting me a discount on some fronts I was thinking either 275/30/18 or 285/30/18.
Where did you get the longer studs at and what length by the way Marco?
Too bad I didn't get em from you Zack
Old Jan 28, 2005 | 07:54 AM
cfdemarco's Avatar
I got the ARP studs from thunder racing...they are 2.5" in length. Take a look at these two pics, the first one is my stock studs, the second is the ARP studs...don't mind my disgusting rotors, my new ones are going on in the spring...
I didn't want to roll my fenders, so I was told to use the 5/16th spacer...but using the spacer, I couldn't get a single turn on the wrench with the stock studs...when I had the ARP studs installed, everything worked out great, there was plenty room for both the spacer and the wheel. One thing you should know- if you plan on using the ARP's and putting them on yourself, you don't have to take the axle off, like the shop told me I would have to- there is an ABS sensor on the back plate, and if you take that off, there should be enough room to push the old studs out and get the new ones in, although you may have to grind the tip of the studs down a little so that it can pass through. Hope this helps, good luck...
Old Jan 28, 2005 | 08:07 AM
Camabird's Avatar
Post pics when you get em on I'm getting black z06s soon but without the rivets
Old Jan 28, 2005 | 12:11 PM
I sure will I'm sitting at home patiently right now
Thanks for the info Marco
I'll probably end up using the BFH mod and rolling the fender lip anyway though. I just wish I already had a mig welder, I'd be mini tubbing my car right now
Old Jan 28, 2005 | 09:38 PM
Well I got the back ones on but it's way too dark to take pictures. The fronts I'm waiting on the Toyo's to be shipped, they should be here Tuesday. I'll post up pics when it gets nicer or when I get the fronts which ever comes first.
and to everyone that said 335's wouldn't fit on a 10.5 inch rim HAHAHAHA!
No bulge the tires look like they were made for this rim
I'll make a new post later with pictures, Thanks for the info guys!
-Archie
EDIT: well I went and tried to take some more pics these turned out better, not great but better.
I had to edit the brightness and such so you could see the pics that's why the color is off. Also, I'm waiting on the center caps they will be here next week and off course I'll have to put undercoating in the wells again.
Tire size
Wheel
Old Jan 29, 2005 | 08:55 AM
1stls1's Avatar
Glad to see everyone is following my lead. J/K I am tring to figure out why you need longer studs. I didn't need spacers or studs!? I am running 17/9.5 tho.
Old Jan 29, 2005 | 09:08 AM
Yea I didn't either, the spacers I got didn't look too safe so until I find some that fit right I'm running without spacers or new studs.
Old Jan 29, 2005 | 09:56 AM
1stls1's Avatar
What I mean is, I didn't NEED them, or have to have them. I guess b/c I got the 9.5, I dont know. But the co that put them on never said a word about studs or spacers.
Old Jan 29, 2005 | 07:38 PM
Wel I thought I had the problem "hammered" out <--(stupid joke) But looks like I am gonna need a spacer I just barely cleared them but when the rear axle articulates it rubs the inner well. More money I'm gonna have to spend
Old Jan 29, 2005 | 07:54 PM
Camabird's Avatar
I just ordered black z06s without rivets I can't wait for them to get here and put some 275/40/17 rubber on em Bought em from the same guy too, check it out...
Old Jan 31, 2005 | 12:18 AM
slayer6x6's Avatar
-Archie
Tire size
Wheel
And use some tire shine before you take any more pics!
Old Jan 31, 2005 | 12:43 AM
I know I know I just didn't want tire shine all over me when I finished fitting the wheel in the wheel well
BTW camabird those look nice I've never saw them on ebay before though?
