A missing lugnuts?
Old Jan 26, 2005 | 01:06 PM
ChrisUlrich's Avatar
A missing lugnuts?
If I had 4 out of 5 lugnuts on my rear tires... what would happen? Anything bad?
Old Jan 26, 2005 | 01:14 PM
1-bad-z28's Avatar
Re: A missing lugnuts?
nothing would happen...i wouldn't be doing too much drag racing but normal every day use wouldn't matter
Old Jan 26, 2005 | 03:47 PM
RE AND CHERYL's Avatar
I would think you would replace the missing lug nut.
Old Jan 26, 2005 | 04:36 PM
BUBBA's Avatar
Take some off the front wheels. The back ones are the ones that all the spinning.
Old Jan 26, 2005 | 04:56 PM
redcamaroz28's Avatar
It'll be fine. My friend raced w/ only 3 one one tire then again, he's not the brightest fellow. Another friend had only 2 lugs on one wheel on his integra (4 bolt pattern) and drove around like that for bout 2 months.
Old Jan 26, 2005 | 05:17 PM
shoebox's Avatar
LOL and the front ones do the steering.
Old Jan 26, 2005 | 05:58 PM
pHEnomIC's Avatar
When i went in for a driver test, they require 4 out of 5 or 3 out of 4 lug nuts on each wheel or better of course. Right before my test i panicked because i knew they checked that and i noticed one was missing.
Why not get another set. autozone has em for a dollar each.
Old Jan 26, 2005 | 06:02 PM
6SpdLT1Z's Avatar
It will be fine aslong as you don't launch too hard, or drive on the highway any... Go buy a new set or something though.
Old Jan 30, 2005 | 10:16 AM
scooters97ss's Avatar
If by bad you mean the wheel working loose and falling off; then yes.
We had a Ford half ton in our shop recently that required over $2000 worth of repair and body work because a rear wheel worked loose. Safety inspection here requires all wheel studs and nuts to be in place.
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
