Substitute for PS fluid?
Old Jan 25, 2005 | 01:13 PM
shouldaboughtthez's Avatar
It seems the wife has ran the PS fluid low and I can't get any till payday. Can't I use like ATF or Brake fluid?
Old Jan 25, 2005 | 01:38 PM
crasher88's Avatar
Re: Substitute for PS fluid?
you can use ATF I know that for a fact but I"M not sure about break fluid. Probably not because power stearing pumps generate alot of heat and break fluid doesn't like heat.
Old Jan 25, 2005 | 01:46 PM
Thats what I was thinking. I'll use the ATF.
Old Jan 25, 2005 | 07:50 PM
Fuels94TA's Avatar
You can't afford a buck for a bottle of PS. I wouldnt mix fluids in the PS pump. Instead of spending a buck for the fluid you might spend $200 on another PS pump.
Old Jan 25, 2005 | 08:10 PM
1 Nasty Bird's Avatar
Lift up your sofa cushions and scrape 2 bux together and go buy some cheap brand power steering fluid at the parts store. If your really that tight right now ATF will work. Ive done it on some older cars i didnt care so much about. Its really almost the same fluid aexcept the ATF has more cleaners.
DO NOT use brake fluid, its hydroscopic (sp?) mening it absorbs water from the air and might get hot going through the pump and make it boil (doubt it unless you beat on the steering but i still wouldnt trust it) then youd have air in the system. Power steering is a PITA to bleed. Also that stuff eats right through paint and who knows what else, wouldnt want it in my steering system!
On another note a leaky radiator can be fixed by dropping a raw egg into the radiator. Prolly clogs other stuff, but if your in the dessert with a leaky radiator and an egg on a hot day all alone you may want to try it out. Works like a charm.
Old Jan 25, 2005 | 08:31 PM
Actually I found a couple of bucks in the back of her suburban, thank god for kids sometimes. Went and bought a bottle.
Old Jan 25, 2005 | 10:53 PM
Spinner's Avatar
ATF works fine. They're both hydraulic fluids.
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
