Wiring Diagram Look Good??
Old Jan 19, 2005 | 02:52 PM
xfreshjiv12x's Avatar
I just got a NX wet kit from here and it didnt come with wiring instructions. So I used the wiring setup on page 3 diagram 2 of this page. should this work fine? http://www.barrygrant.com/fromBarryG...PI-NITROUS.pdf Also I dont have a full throttle pusbutton but I have a Jimmy jams WOT is that the same?
Old Jan 19, 2005 | 02:56 PM
MEAN_SBC's Avatar
Re: Wiring Diagram Look Good??
Yes, that wiring diagram should be fine, since all solenoids work the same. If you're looking for NX specific instructions, they can be found here:
NX Instructions
Old Jan 19, 2005 | 03:16 PM
Yea I found that one but apperantly the relay switch is different from that one because I have no white wire. Thanks for the confirmation
Old Jan 19, 2005 | 03:28 PM
BTW Where should I hook up the switched power supply inside the car. Is the ORANGE wire under the shifter good to splice into?
Also I just checked the system I dont have to switches hooked up yet, but I put the wire that hooks up to the switches to the orange on the cig lighter (just to test). The car was running and I have No nitrous in the bottle yet but the fuel is hooked up. It started making clicking noises and a little fuel sputs out. Iam I in trouble?? I thought the fuel would spray out? or does it spray out when you get the nitrous and fuel mixed?
Old Jan 19, 2005 | 04:05 PM
MEAN_SBC's Avatar
The wire you use should be able to handle the current from the nitrous system... I would use the ignition wire... Test the pink wire in the ignition harness. Make sure you fuse everything!!!! Use a meter, and make sure you solder into the right wire...
It's hard to say if you have everything hooked up correctly without looking at it, but with a small jet, the fuel doesn't usually "spray" out. The nozzle will atomize the fuel with the nitrous when they are mixed.
Old Jan 19, 2005 | 04:11 PM
Ok thanks sound like I got it down. Ill test that pink wire. How much volts should it be?
Old Jan 19, 2005 | 04:25 PM
MEAN_SBC's Avatar
Should be a 12volt ignition wire.
Old Jan 19, 2005 | 04:36 PM
Cool! thanks Mean SBC!!
Old Jan 19, 2005 | 05:18 PM
MEAN_SBC's Avatar
No problem...
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
turbo_Z
Aug 19, 2002 10:50 PM
