Nitrous On A 93 ????
Old Jan 18, 2005 | 07:02 PM
SPEED750's Avatar
I have a 93 and the fuelrail doesn't have a crossover in front like the later models. If I use the rail to supply gas to a 150 shot, will it cause the right bank to run lean? I'm running a walbro 255. Anybody have any experience with this?
Old Jan 18, 2005 | 08:24 PM
SDAKOVIC's Avatar
Re: Nitrous On A 93 ????
I use the Nitrous Works wet kit on mine with the 175 jets and a 9 p.s.i. super charger with no problems at all.
Old Jan 18, 2005 | 09:36 PM
MEAN_SBC's Avatar
With a walbro 255, and 150 shot, you'll be fine.
Old Jan 19, 2005 | 03:16 PM
whatsup's Avatar
Same question here...I'm planning on running the std NX kit w shark nozzle and STOCK pump?
Old Jan 19, 2005 | 03:22 PM
ltwonz's Avatar
The crossover is on the back on the intake and works the same way.
Old Jan 19, 2005 | 04:10 PM
MEAN_SBC's Avatar
With the stock pump, I wouldn't go much bigger than 100 shot... Just to be safe... Running the mix lean is the worst thing you can do...
Old Jan 20, 2005 | 08:15 PM
jcolez28's Avatar
Ive done lots of 100 shots on my 93 with stock pump. I just bought a new walbro pump to run 150 just to be safe.
Old Jan 21, 2005 | 12:07 AM
MEAN_SBC's Avatar
Good play..
I've seen plenty of 100 shot cars with stock pumps, and no problems.... On more spray than that, a stouter fuel pump definitely keeps you on the safe side.
Old Jan 21, 2005 | 11:28 AM
whatsup's Avatar
Thanks for the info...well I guess I'll go with the 100 shot and upgrade pump later if I need a bigger shot. I want high 11's...besides my mods below while I'm installing the nitrous I'm adding MSD6AL w/single stage retad box and window switch, 58mm BBK TB, 30lbFMO injectors. Think I can break into the 11's with a 100 shot?
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
