FS: Autotek Mean Machine MX500 amp
Old Oct 8, 2002 | 07:15 AM
ChameleonGreen's Avatar
The Mean Machine amps are Autotek's top of the line stuff. The amp is less than a year old and is in very good shape.
2 x 125watts at 4ohms
2 x 250watts at 2ohms
2 x 425watts at 1ohm, yes it's rated to be 1ohm stereo stable
1 x 500watts at 4ohms bridged
1 x 800watts at 2ohms bridged
Black chrome chassis, 1 RCA input, 1 RCA output with high pass low pass or full range out, subsonic filter on/off switch at 35Hz, high pass from 75-750Hz, low pass from 40-150, bass boost 0-24dB at 42Hz, built-in 60amp fuse and I will provide a seperate 60amp round glass AGU fuse without holder for near battery protection.
You can use this amp for anything. A pair of components, 4coaxs (but you will only have left-right fading, no front to back with that set up), or use it to power your subs.
$350 shipped, you will not find it cheaper anywhere. please email for questions. nin@austin.rr.com
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Z Power
Sep 19, 2015 11:19 PM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
karpetcm
Aug 14, 2015 03:02 PM
