N2O with Vortec elbow?
Old Jan 2, 2005 | 10:23 PM
jcolez28's Avatar
I just got this part and it doesnt look like it will work. there is a divider that looks like it will interfere with the pattern. Anyone else try it?
Old Jan 3, 2005 | 02:18 AM
Derrick Redd's Avatar
Re: N2O with Vortec elbow?
I've seen a few people on here that use it and claim the divider doesn't affect anything. You could cut it out. I went with the Trickflow elbow. It has no divider.
Old Jan 3, 2005 | 09:42 AM
speedmiser's Avatar
I didn't feel comfortable putting my alky injection nozzle in the Vortech elbow until I cut the divider out. I wouldnt put a nitrous nozzle in either, without removing the divider, no matter how many other people had done it w/ the divider intact.
If the vortech elbow is something you received new, I'd return or exchange it and get the Trickflow, as mentioned by Derrick.
Old Jan 3, 2005 | 10:28 AM
joshp007's Avatar
Just cut the divider out. Thats what I did and then tapped it for NOS. Good luck bro
Old Jan 3, 2005 | 10:43 AM
sniffin94's Avatar
my good friend my95T/a didn't cut the divider at first and melted a couple of #2 plugs because the nitrous wasn't getting distributed evenly. After he cut it out no more problems. I would definately cut it out
Old Jan 3, 2005 | 03:52 PM
n2oCamaro's Avatar
I was thinking of putting together a custom system similar to the TNT plate kit only with the two nozzles on both sides of the vortec elbow. Any thoughts on this?
Old Jan 3, 2005 | 05:09 PM
sniffin94's Avatar
I would say that would be a much better option. Depending on how big of a shot you spray, I don't know if I would trust the dual nossles above a 250 shot though.
Old Jan 3, 2005 | 05:31 PM
speedmiser's Avatar
That would work just fine and would allow you to spray 200+. If you're not planning on spraying that much, a single nozzle with no divider would be much cheaper, cleaner, and work just as well.
Old Jan 3, 2005 | 06:36 PM
jcolez28's Avatar
The elbow looks killer is why I chose it over the TFS. What tools are you using to remove the divider? It is a pretty stout piece of aluminum. A dremmel doesnt seem like it would be strong enough. Also I checked on spraying both sides and you divide both sides by total power. I figured by the time you spent the extra cash for the nossle and lines and jets it would be high. Thanks
Old Jan 3, 2005 | 08:05 PM
sniffin94's Avatar
my friend cut his out with a mini air saw, it wasn't the easiest thing to do but it was necessary. I would saw cut it out any way you can. Good luck
Old Jan 3, 2005 | 08:46 PM
n2oCamaro's Avatar
I am wanting to start at 150 and go to 200. I like the idea of nozzles on both sides for even distribution, but I think the TNT kit places the nozzles to close so that the front cylinders (1/3 and 2/4) have a harder time getting a good gulp of the juice.
Old Jan 5, 2005 | 06:49 AM
CoUnTryMuZiCZ28's Avatar
That divider isnt all the way through that elbow.. It starts about part way. you could just put it before the divider.
marlar98
Oct 21, 2015 02:02 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Slayer
Aug 17, 2015 03:55 PM
1995Blackz28
Jul 20, 2015 09:34 AM
